Puget Dude’s creations and fabrications (Random project thread.)
Fixr
SW VA
Even without code requirement, I think it's a good idea. I do leave about a 1" gap front and rear in case there is a leak. You don't want that trapped underneath.
Personally, if there is a leak, I want to know about it by the time I buckle my belt after flushing, not years later when the flooring collapses.
rharman
SoCal
Exactly....
P
PugetDude
Superstition Mountains, AZ
Finished welding and installing new gates for the front porch and back deck at the summer place. Previous owner just had all new redwood deck railings installed, with hundreds of 2x2 pickets. We wanted to go with a more contemporary look (my bride calls it "mountain industrial" so the pickets had to go... (Including 100' of matching fencing on the dog run... More on that later)IMG_20250713_170530127_HDR.jpg
I don't have the garage space (or the motivation 😉) at this new place to spend the summer welding up railing sections like I did the last two summers, so I elected to go with pre-powder coated "Wild Hog" railing panels from Agent Orange, using the existing deck rail framing.
The panels and frame sections are a little pricey, but almost competitive with welded sections that get sent off to powder coating.IMG_20250713_183022072_MP.jpg
Had to build (4) gates, two each for the front porch and back deck.
Also built the hinge hardware to hang them, the standard 5/8" diameter gate hardware is too bulky for these small gates, IMO. Used 3/8" x 4" lag bolts, 3/8" x 2-1/2" carriage bolts, some 1/2" round bar, and 3/8" S40 steel pipe. Bit of welding and a bit of grinding ...and some more grinding...IMG_20250816_174323929.jpg
I built the gate frames entirely out of steel sections and tubing I had left over or lying around from the deck panels last summer, the patio furniture , '32 frame, etc..., the 4"x4" wire panel drops were pieced together for the infill. Only out of pocket cost was the powder coating.
Front gates installed, rear ones still need a bit of adjustment and a receiver for the cane bolt. Should get that done tomorrow.
larry4406
Northern Virginia
Nice job on the railing transformation!
The wire panels much more subtle and retains the awesome views.
P
PugetDude
I Really like that upgrade….always seems you are thinking out of the box and not the status quo.
Speaking of that when does the car get some love ?
I will start working on on the '32 again when we go back to the Valley of the Sun for the winter. Between the house move and projects up here I elected not to bring it up this summer. The new garage setup isn't really conducive to a hot rod project, either.
Though, I do have another BIG project planned for this winter ...😉
P
PugetDude
Got the back gates off the deck and new dog run finished up today. Had to fab up a little weldment for the cane bolt.
1/2" S40 pipe and a piece of 3/16 plate that already had a couple of holes in it. Added a 1/4 thick spacer in between to get the right offset to match the centerline of the cane bolt. Installed it with a couple of 1/4" Tapcon Concrete Screws.
@Dan in Pasadena, this picture is for you: 😉
Finished removing the old 4x4 redwood fence posts. What do you do with a pile of 5' long redwood 4x4's???
When your gravel supplier "helpfully" delivers twice what you ordered, you make a couple of walk-off steps to transition between the pad at the bottom of the stairs and the yard. Had to use it up somewhere...IMG_20250819_134717990_HDR.jpg
We re-used every bit of the old deck railings, posts and fence rails on the new (smaller) dog run. Moved it to the other end of the house, used the wire panels, the leftover redwood, and 1/2" decorative gravel for the base, with a 5x7 piece of artificial turf.IMG_20250819_132938753_HDR.jpg
The bark chips the previous owner put down were way too absorbant and aromatic for ground cover with their 3 big dogs, let alone our two little ones....had to rake out 6 heaping wheelbarrow loads.
There were probably 500+ redwood 2x2's left over, neighbor from my old place wanted them. Delivered them for free, happy to just get them out of here.
Moving on to the next project, my bride says she is going to do the sanding and touch up staining. 🤞
P
PugetDude
We used hot-dipped galvanized hog fencing in the same manner; it almost disappears when looking through it.
Looks great, Bart.
I used these same panels on my old place, welded them into 1-1/4" square tube frames, then had them powder coated satin black.
Yours look great with those galvanized knee braces.
P
PugetDude
Clearly I have. And a lovely little fireball she is too. 😁
Don’t feel bad bud. My entire life seems to be everyone around me has months to come up with idea or just flat out f things into the ground. Then it gets thrown into my lap and I’m allowed 5 minutes to come up with some resolve. 🤬
I am currently researching the best way to update the dark-stained log posts in the loft to match the interior millwork..
Alder to match the cabinetry and doors or natural pine to match the ceiling?
Lock miter wraps, solid posts or??
Hmm... this might take some time... :unsure:
LXCam
Well its a damn good thing that place was move in ready and you didn't need to touch it. This should be easy :spit:
P
PugetDude
Riiiiiigggghhhttt...
Closed in June, so far we have...
1. Expanded the parking area and driveway, moved boulders, spread 5 trailer loads of gravel
2. Changed the water heater to tankless
3. Changed toilets to comfort hight
4. Added a powder bath
5, Re-did 100+ feet of deck railings
6. Built a new 16 x 24 dog run
7. Tore down the old 100' long dog run, removed 12 4x4 posts set in concrete.
8. Built a 4'x11' wooden fenced enclosure with a gate for the trash can and extension ladders
9. Re-worked all the irrigation lines.
10. Had 6 big fixed-pane windows replaced.
11. Framed and drywalled a new closet in the laundry room
12. Added sliding bifold doors to that closet.
13. Designed, built, and installed 4 welded steel gates with custom hardware.
14. In between all of the above, I am trying to consolidate my 3.5+ car garage and shop at the old house into the new 2-car garage. Gave away a lot of stationary power tools, built roller stands for others, built in and/or downsized my benches,
Yeah, I'm tired.
And the summer ain't over yet...
larry4406
Northern Virginia
Yeah, I'm tired.
And he’s not even counting yet!
Jgaz
Yeah, I'm tired.
What have you done in your spare time?😉
P
PugetDude
Well, finally finished up a little project this afternoon. Stone and steel address marker for the new summer place.
Welded up a little frame out of some 2" and 1-1/4" square tube. The 2" came from the gates I took down, the 1-1/4" was pieced together with drops from the deck railing project at the old place. The lower support brackets were modified from the old gate hinge brackets, just welded 1/4' x 1" tabs on them to support the flagstone.
Got it set in concrete in between rain storms, used a couple of bags of the fast setting post mix. IMG_20250919_083209670.jpg
The 8" numbers were purchased from Industrial Metals, at $6 each it wasn't worth trying to cut them out of plate I didn't have. They are mounted with 1/4" all thread with (2) 5/16" nuts for standoffs. Ordered 1/4" black acorn nuts for the exposed side.
Added a pine tree to fill out the larger end of the stone, because A) I thought it needed something more interesting than just the numbers, and B) we are in the largest stand of Ponderosa Pine in the US.
It's a little hard to see, but I did texture the tree with welds for the trunk and grinder marks for the branches. IMG_20250919_215027.jpg
Unfortunately, most of my attempt at art disappeared when I painted it. Screenshot_20250919-214152-925.png
Got everything painted and mounted just before the skies opened up. Calling this one done. IMG_20250919_162350217_HDR.jpg
Jayman17
Seattle, Wa
I like your address project. Do you drill the stone with the hammer setting or without? I've wondered if stone like that would crack if you use a hammer drill. Looks real nice!
P
PugetDude
Ryobi 18v rotohammer with a 3/16 bit, went really slow, light pressure so the bit barely got into hammer mode... Then a 1/4 bit to open the holes up. Did get some blowout on the back side, but no way to avoid that with flagstone. The stone is 2"-2.5"+ thick, probably weighs 160+ lbs. I could ******** spleen when I picked it up and put it on the sawhorses. Probably getting too old for that...
Bob Heine
Boca Raton, Florida
Scott, absolutely beautiful address presentation. It's a shame the paint hid the texturing on the Ponderosa pine. You might try dusting some gray spray paint (same brand) on the tree and wipe it off the high spots to bring it back to life. If i doesn't work or looks horrible, a fresh coat of black isn't too big a deal (he says while his fat *** is parked at his desk).
P
PugetDude
Thought about doing that with a very dark green on the tree and brown on the trunk.
Just a very subtle hint of color, don't want it to look like a kindergartner's art project hanging on the refrigerator.
I'm back in the Phoenix Inferno for a few days for a couple of appts. Might try something when I get back up north- almost time to shut it down for the season.
e015475
Show Low and Mesa Arizona
Yeah, I'm tired.
At our place in Show Low, I have a bunch of windows where the seal has failed and the window fogged that I'm going to need to replace.
Did you use someone here on the moutain for your window replacement? Any details appreciated. I talked to Liberty and they wanted $250 to come out to estimate.
P
PugetDude
A-1 Glass
Snowflake AZ
No charge for estimate
$1000 less than Demers
They mis-measured 2 of the windows, had to come back, but they handled it well.
Really nice people to deal with.
LXCam
A-1 Glass
Snowflake AZ
Demers, I know the owner Don. He's a nice guy and runs a tight ship but they ain't cheap by any means. Plus he'd be sending guys out of Phoenix so there's that.
But I'll share a recent emergency. Mental health ward, dude starts beating on the interior of a exterior window with a chair and shatters the interior pain (but remains in tact). This glazing panel is level 3 ballistics and exterior rated. 2ft wide, 7ft tall AND custom made thicknesses because of a architectural design and coordination flaw between structural / storefront framing design details with Demers stuck figuring out and providing a solution at hour 12 of construction.
Anyhow, I get the call to source the panel since I'm the only guy in town with that connection. My cost - $5K but I refuse to install it because of this custom storefront framing horseshit and other reasons. Long story short, between me passing on the pane and two different contractors involved with its installation, the overall job was $25K. Guess who the stakeholder called first bitching about the price - ya guys it wasn't me - keep on looking.
P
PugetDude
Demers has a shop in Pinetop, AZ. Had them replace a few windows at my old place. Not.impressed. at. all.
