LinuxMercedes
I'm rebuilding an air compressor pump and I need to pull a ball bearing off the crankshaft so I can replace a con rod. The bearing is one of these and it's pressed up against a shoulder on the crankshaft.
There might be just enough of the inner race protruding that I could maybe drive it off with a drift. Or I could use a 3 jaw puller and grab it on the outer race, but that would ruin the bearing.
What do you all think? I know there exist bearing pullers that can grab the inner race by the groove the balls run in, but they're $700+ on eBay!
