PVC Conduit above Grade??
dirtrunner0519
Does conduit above grade have to be EMT. I am going to pour my patio and cannot seem to find if it needs to transition from PVC to EMT. It will be a few dulpex outlets 110V @ 20Amps with a GFCI. Location is Los Angeles
Shiftless
East Bay SFO
I don’t like pvc conduit because it sags. But EMT will rust if not kept painted.
For a short vertical run in my front yard, I used intermediate conduit wrapped in 40 mil tape.
tonyprovo723
Probably a question that needs a response from someone local as this varies by local code. Western suburbs of Chicago, metal pipe above and below ground. An hour west of Chicago and PVC is fine.
The comment of grey PVC, is incomplete. I'm not a plastics guy, but grey pvc is for electric and white is for plumbing in the general scheme of things.
Have you talked with the local inspector? Granted some want to show their authority and will hang you any chance they get. Other inspectors simply want you to do what is safe.
mobiledynamics
Gotham City
How about aluminum ridgid ?
Spark used that on my job recently and I was quite happy and surprise....here I was thinking I would need to be maintaining paint on EMT...
D
dirtrunner0519
I have talked with the inspector, and he said PVC is fine but then I got a different inspector and he said I need emt/rigid.
lakeroadster
Central Colorado
Typical.
Call the jurisdiction and ask for the Head Inspector. Follow his instruction and write his name down. Then if anybody questions what you are doing... tell them who you talked to.
dogdog
I have used the GRC/RMC for outside and buried under ground past 3 years+ not even a rust spot (well I can't see underground )... but it's 3x more than EMT though cost wise..
Crazyjake8493
Upstate NY
There is nothing prohibiting PVC above ground, though if subject to damage it is supposed to be sch 80. I like to use PVC outdoors and EMT indoors.
electroman187
NH
Another problem with PVC used above ground outdoors is its high thermal coefficient of expansion. If the calculated variation is greater than 1/4" for a length, then an expansion joint must be used. In NH with a seasonal temperature swing of more than 100`F, that's less than 10'.
zmaxmotorsports
South of omaha
Well if you get enough frost in the ground anything can move including emt.;)
But I always use expansion joints on pvc coming out of ground outdoors.
Cheap insurance.
electroman187
NH
Cheap insurance.
Yup, I agree with that. But we are talking about 2 different things. You're talking about frost heaves causing a shift in conduits emerging from underground. I am talking about the change in length of a conduit due to thermal variation.
For instance, anywhere in the US where a 20' PVC conduit length is outdoors and above grade, there should be an expansion joint along with the proper PVC supports that allow the conduit to slide within it. However, the same steel or aluminum conduit run would not require the expansion joint. I see these expansion joints missing all the time and as a result, I see a lot of ugly sagging runs, couplings pulled apart (shrinkage) and broken out junction boxes (expansion).
In fact, even when burying PVC care must be taken. If the air temperature is significantly hotter or colder than the ground temperature, then there can be problems that occur once buried. If it's very hot out and conduit has been laying in the sun, it is fully expanded. Once glued together and buried, it cools and shrinks and the couplings can pull apart if they are long runs.
zmaxmotorsports
South of omaha
:thumbup::thumbup::thumbup::thumbup:
I normally don't run pvc horizontally outdoors,just because of all the extra strapping required to keel it from sagging.
NUTTSGT
Northern Central Ohio
While you guys are talking expansion joints for the conduit and the OP is in Los Angeles.
Since Southern Cal has some earthquake issues and has building requirements to fit those shaking tremors, do they require expansion joints for conduits as a regular item ?
Just curious here ?
alfredeneuman
Fullerton, CA
The Code in So Ca is the same as that for the rest of the USA, without addressing any seismic issues.
(The California Electrical Code is taken verbatim from the NEC, the only difference being that the California Energy Code is incorporated into it.)
D
dirtrunner0519
I thought i posted I went with PVC stub ups. This is only for our patio area (110V) and to feed and LV lighting for landscaping.
