FredWanaker
Have 4" PVC elbow as part of the shed, roof, and awning drainage system. One of the contractors hit it with something about 10 years ago and broke it. I glued the thin pieces together but it needs to be replaced. I am trying to think of a way to cut it at the ground where it goes into concrete, insert some kind of coupling and hook it back up to the drain. One solution is to chisel out the concrete around it. Another might be to cut another elbow slightly longer than the piece coming off, heat the bend area and try to shrink it to fit inside the piece in the concrete. Anyone else have any ideas, PVC sheet that rolls or up and can be glued as a tube, flexible tubing that would fit inside both pieces. The piece that comes out of the ground immediately is glued to a piece the drain spout goes into. I'll try to get a photo tomorrow. The problem is that on an elbow, each end is expanded to fit the 4" PVC. Then it necks down at the bend. One of the expanded sides is in the concrete so some chiseling is needed if the whole piece were to be replaced. Digging is required if I have to get down to the 4" PVC or it could be styrene. I don't recall but PVC glue held it together when it was assembled 25 years ago. Its purpose is to carry runoff from the spout into the drain then to the street.
