Pvc french drain depth
Reit38
Iowa
I'm planning on burying a 55gal plastic drum for my shop drain outside of my shop. I'm planning on getting the top of it 14-15inches below grade. So I'm assuming my 2in pvc will be around 12-14 below grade coming out of the shop. Any issues with driving a small utility tractor over it in the future or should I try and get it deeper.
dcg9381
Austin, TX
Our main water line is 2" PVC, it's probably 12-18" below grade in some places. I regularly drive a Polaris over and have driven over it with a 6000lb pickup. It may depend on how "expansive" your soil is though, the trench here is pretty much limestone.
I don't think I'd worry about your basic lawn tractor..maybe not a compact tractor either.
You could always go schedule 80 if you're worried about it.
That being said, you'd be surprised how much water comes off buildings. We capture about 3000 gallons per inch of rain of the shop, not quite the same as a french drain, but 55 gallons ain't much capacity. If this is a gray water drain thing, I get it.
I wouldn't drive over the drum.
R
Reit38
Iowa
Plan on drilling 1 inch holes around bottom half of barrel and covering with landscape fabric Filling bottom of hole with clean stone 2-3 inches thick
NUTTSGT
Northern Central Ohio
That would be a real french drain. Sounds like he just wants a drain line, but how will the barrel be emptied?
French drain is a trench with or without a perforated drain line in the bottom filled with stone to carry water away.
Drywell is an area or container full stone designed to hold water after it is moved away and slowly release it into the surrounding soil.
OP will have a 2" line underground to the plastic drum. Drilling the holes along the bottom will allow it to slowly drain. The stone helps with the dissipation of water and helps to also keep the barrel from floating out of the ground.
racecougar
Missouri
So you're doing a dry well connected to your floor drain. As said by myself and larry4406 above, if this is in Iowa, as your location states, I'd suggest going deeper for frost depth purposes.
441510048_10100987052751383_7707945600700251251_n.jpg440371869_10100987052721443_6482236374932753676_n.jpg
PopcornSutton
Northern Tip of VA
The OP didn't say he intended on any stone fill originally, just a 2" pvc pipe and pvc drum, and nothing about stone or holes in the drum.
dcg9381
Austin, TX
We have a "gray water" drain for the shop. Around here there are code / water discharge requirements. But what I did was use 4" drain PVC all along the south side of the shop foundation and back filled it with septic rock. It's "tucked" in against the foundation so running over it isn't an issue. Probably not as good as a drain system where you could pop the top and clean it out though...
NUTTSGT
Yes, that is why I asked about it in post #7.
Sometimes, you have to ask a few questions to get more information to help a fellow member out.
R
Reit38
Iowa
As of right now the bottom of the hole for the drum is roughly 56 inches deep. Barrel is roughly 39in tall if I remember right. Planned on 2-3 inches of clean rock and the bottom of the hole
R
Reit38
Iowa
39" tall sounds about right.
I believe most plastic drums have one bung that is NPT and the other one is something coarser.
Just measured again and it is 39. I plan on using the NPT fitting with the pvc
egdede
I wouldn't put it right up against the foundation/slab/thickened slab edge, etc. (as pictured above).
racecougar
Missouri
The one pictured above is only catching water from the little trench drain in front of the walk-in door, and that building has a full foundation 12" deeper than local frost depth.
