PVC pipe question, need to debond
TT_Vert
Wauconda, IL.
So I am removing a double bowl sink and replacing w/a single. The original installer glued everything and I don't even have enough of a stub (I don't think) to slip anything over what is there. I would just cap the one if it wasn't exactly in the way of where the drain is going to be. What would you guys do in this situation? Taking the cabinet out to run new PVC is not an option.
Thanks much
Dave
GarageGuy89
Olalla, WA
Had this same scenario for our kitchen sink. Ended up using a rubber boot/coupler. Just make sure its a tight fit.
T
TT_Vert
Wauconda, IL.
I've really got nowhere for a coupler. After I hack off that Y fitting I'm going to have maybe 1/4" of material there. No way a coupler will work there. I'm googling and it seems I can heat the glue to debond it. Hows the success rate there? Someone used a hole saw they heated to bring it all to a consistent temp and then removed. May also try that.
Dave
The Cobbler
cut the Y off, leaving the hub around it . get a rubber coupling that will slip over that ,\probably 2"x1-1/2" would tighten on there.
or go into the wall and cut and replace the t etc/
you can also buy bits that will ream out the pipe from the hub. probably cost about $20 for 1-1/2"
HeelSpur
WV
I've cut the hubs off many a time but its time consuming.
Cut off the fitting right at the hub and make cuts with a hack saw down to the pipe and slowly chisel off. I'd like to know of a better way myself.
Falcon67
Merkel, TX
Cap and attach an air compressor. Oh wait, no control over where PVC separation occurs. NM.
That reamer looks like a cool tool. Have to remember that.
Leaflessshadetree
Don't ask.
Cut the pipe at the fitting and ream out the fitting.
I believe the tool is usually called a fitting saver (or something like that). The cheap tools work OK for one time or occasional use.
MoonRise
Yup, as said you cut the pipe at the fitting and then use the power reamer to remove the pipe remains that are still glued inside the fitting.
Works great. Clean out the goo, wipe out the fitting well with some rags, prime and solvent glue back together with some new pipe pieces. Done. BTDT. :D
Oh, start the drill (with the reamer bit in it) slowly and really try to keep the reamer centered in the fitting. I also like to run a chamfering tool around the cut pipe end that is in the fitting to smooth it out a little and help me get the reamer bit centered a little better than just slamming the spinning bit into a piece of pipe at 'high' speed and hoping for the best. :lol:
T
TT_Vert
Wauconda, IL.
Heated a socket w/ my torch and put it in as I didn't have a hole saw that size. Was able to get it warm enough to debond the glue. Got it out cleanly so I'm good. Thanks much guys
Dave
rlitman
Long Island
Dave
Well done. I only just saw this now, but for future reference, I use a heat gun to soften the glue. A screwdriver and pliers then can pick out the pieces you need to remove.
T
TT_Vert
Wauconda, IL.
Thanks I considered that but I didn't want to heat the fitting I need to retain tooo much and oblong it in any way.
Jackfre
N CA
Get a multi tool and cut the cabinet back a few inches to either side opening things up so you can work on it. Cut the pipe as far back as you need to and replace the drain and vent pipe. Get “no-stop” couplings or take a half round file and file the stops out of a standard coupling. Or, use no-hub couplings. Once you have done this use a piece of 1/4” tempered hard board to repair the cabinet back. So you should need two coupling, 1-San tee and a 1 1/2” trap adapter. The vent is probably 1 1/2” and the waste 2”.
GarageGuy89
Olalla, WA
Dave
Can you post pics, so others can see how it turned out. Still not clear on where the tie in is...
rlitman
Long Island
While PVC will get soft when you heat it, it's pretty springy, so it will return to its natural shape so long as you're not holding it in an oblong shape as it cools down. Just don't try to glue it while it's still hot.
T
TT_Vert
Wauconda, IL.
Yeah I wasn't sure so I didn't chance it. Anyway, here is the final product per request.
LS6 Tommy
Northern NJ
flat350
illinois
Sometimes it helps to put a hose clamp around the outside of the fitting hub that your'e trying to save,it reduces the chance that the hub will crack.
Flail
Kin folk said, “Californias the place you wanna be
For abs I’ve used 2 hole saws on one arbor. Smaller hole saw fits inside the inner pipe and works as a guide. The larger hole saw matches outside diameter of the pipe you are cutting out. Standard arbor won’t have enough thread to get both hole saws on so bought a bolt and cut the head off. This provides enough thread to nest the hole saws inside each other.
T
TT_Vert
Wauconda, IL.
BTW, had to debond more pipes today and I didn't want to have to wait to heat a socket so I went and bought that tool and all I can say is that that tool is freaking amazing!! It cleaned out everything in less than 30 seconds. I probably won't use it again but I can appreciate a well designed tool. And now I know what that tool is if it ever comes up in conversation :) Thanks again guys.
rburke65
Canfield, Ohio
Thanks TT Vert.....ya taught me something today with the torch. And, for th3 cost of that tool everyone should own one.
GMCGarage
Thanks much
Dave
heat it up with a heat gun, it works. Then re-glue.
