Quality LED replacements for 8 ft T12?
2slow
I have several 8 ft T12 lights in my two buildings for a total of 44 single pin bulbs and 4 double pin HO bulbs. The magnetic ballasts hum, more light is always better.
I looked into replacing the fixtures with tandem t8s, but I really don't feel like replacing all the fixtures. I am intrigued by the ballast bypass LED replacement bulbs, but the only ones I have found are from companies I never heard of. They may be big in the light bulb world, but I don't know. I don't want to install a bunch of junk in the shop. Does anyone have positive experience with a direct 8 ft t12 LED replacement?
Thanks,
Joe
Crusarius
Upstate NY
I have never seen an 8'.
I got a set of hyperikon and am very happy with them. they are approximatel $12 per bulb on amazon.
Shiftless
East Bay SFO
"I have several 8 ft T12 lights in my two buildings for a total of 44 single pin bulbs and 4 double pin HO bulbs. The magnetic ballasts hum, more light is always better."
I too have never seen 8 foot conversions. The single pin ones are also I think non convertible.
IMHO, you will end up replacing all of your fixtures in order to take advantage of LED technology. Sorry.
Crusarius
Upstate NY
ther hyperikon I purchased came with the tombstones.
I actually rigged up my own wiring harness with a plug on the end since my shop is very ghetto right now. I use spring clips to hold them on the ceiling. also makes for quick easy drop light if I need to just grab one.
jtpfarm
I have the 8' available if anyone is interested. I have all 3 pin styles available.
jtpfarm
They are $44. They have 5280 lumens with a clear cover. We do not stock the frosted cover due to the fact it cuts the lumens down. CREE chips and Bridgelux drivers. 5 year 100% no questions asked replacement warranty.
Crusarius
Upstate NY
I prefer the frosted lens. its a lot easier on the eyes when you are laying on the floor looking up.
They just installed a ton of the clear lens ones at work. That area sux to work in.
chruler
Vermont
LEDs need to have good diffusers on them or you'll get several shadows fanning out from each tube. Each little LED in the strip/tube will cast it's own shadow.
jtpfarm
I can get them in frosted cover if that is what you prefer. Most of what I do is 14-20' ceiling height so the clear lens doesn't bother as much.
Hornman
Southwest DFW
I replaced all twelve of the single pin 8' flourescent tubes in my shop with conversion LED tubes from eledlights.com. They supply a wiring diagram for bypassing the ballasts. The drivers for the LED's are inside the tubes. You supply switched 120VAC to the tubes. I bought the 5500K color temp tubes because I like daylight type light in my shop, but they offer cooler color temps. The LED's are a lot brighter.
