Quality reciprocating saw blades?
SuzukiGS750EZ
Hey guys. My Milwaukee axe blades leave a lot to be desired. I go through them rather quickly. I'm going to be taking down a handicap ramp soon and would like to buy some new blades. I mostly use longer blades, 9". What's recommended? I'll be using my Milwaukee m18 fuel sawzall.
Miss the Pontiacs
Saskatchewan Canada
I asked the guys at the volunteer fire department where i grew up. They use Lennox found them a hell of a lot better than some Dewalt I had purchased. But the Dewalt case was pretty good. 👍I’ve also.had pretty good luck with Bosch.
Rusty Wrench
From home center stock you can't beat the Diablo carbide steel demon blades, IMO. I cut a lot of rusted fasteners and some stock and get more life out of them than the Lenox or Dewalt. I try to cut with the forward portion. As it dulls cut it back with a cutoff wheel.
FMB4
Lennox again. Been my go-to recip, jigsaw and hacksaw blade brand since the late '70s.
I've also had good luck HF's Warrior brand recip blades (both metal and wood).
Fialaja
If your not happy with the ax blades, I would go with the carbide diablos. I personally love the ax blades, but will also use Bosch, Lennox and dewalt
eejack
the garden state
For metal cutting Diablo Steel Demon blades. I use them all the time for demoing rigid conduit, and I recently had to cut the steel bumper on a ram pickup truck to get it out of the tires. Two clean cuts, dead straight with a cordless sawzall in a couple of minutes.
edit: quick research indicates these are the carbides recommended by others above.
Kscardsfan
The Little Apple
Freud or Diablo (can’t remember which right off and I’m not at home) or Milwaukee seem to be all I use. I know some guys love the Lennox stuff, but I’ve never gotten to try them out at length. At the end of the day they’re all expendable wear items, so I don’t worry too much about them when they **** the bed finally.
Qualitytools
SOCAL
+1 on Frued, Diablo or Bosch. Make sure the blade is made in Switzerland or Italy. I recently saw a Milwaukee blade made in Switzerland
Sportsman762
OH
I have had good luck with the MK Morse Carbide blades when cutting steel. They make nice big chips and cut fast.
KnurledNut
n/a
Lenox or Diablo Carbide when things get real.
I cut this in half with the one Lenox blade pictured. The teeth were still reasonably sharp when i was done:
