green.bubbly
I was looking online at Home Depot and saw they sold 2-2-2-4 aluminum service entrance wire. Assuming the "4" is the ground, why is it a larger gauge? Surely I am not understanding something...
The four is smaller than the two. Wire gauges are a weird scale, 12 gauge is bigger than a fourteen and a ten is bigger than a twelve. And so it goes until you hit the ought series 2/0, 4/0 the wire gets bigger until you hit the mcm series. Then the numbers make sense. Bigger number, bigger cable in the mcm series. Not sure who came up with the gages for wire and sheet metal but I would bet it’s an British holdover.
Other is that SER is typically (outdoor only)
Be aware - I found that it's cheaper to order this wire online than it is at HD... At least in lengths of 75' or more.
Other is that SER is typically (outdoor only) - probably can't be used to feed an interior panel... (Just in case you're thinking about doing it that way).
I stand corrected.. MHF - outdoor.. Watch that indoor (insulation) rating.
if youre saying MHF cant go inside, that is also incorrect.
Here's what I'm saying:
It has to be rated for indoor use.
Yes and MHF is rated for indoor use.
You implied otherwise.
Mostly but maybe not all of it. I showed mine to the AHJ and asked about inside conduit - "not required". Easy enough.
Because 1 small town building inspector said it's not required doesn't necessarily make it so.
Just saying what I was allowed, and he was a big city inspector. YMMV.
How did you secure the exposed MHF conductors to the building?
They just run through the attic like every other cable in that space.
