md21722
I have a very old dual stage Champion air compressor, but I think this question may apply to all types of compressors.
Basically the first 20 psi of pressure it generates in about 1:37-1:45. Every subsequent 20 psi takes about 3:00.
This occurs if the tank is empty and its starting from zero psi (for example 0-20 would take 1:40 and 20-40, 40-60, 60-80, ... would each take 3 minutes), or if the tank has 80 psi and its starting from there (for example, 80-100 would take 1:40 and 100-120, 120-140, .. .would take 3:00).
Is this somehow built into the design or possibly related to a valve problem or other?
Pump is an RE-7 without unloaders. There is a check valve with an unloader line to the pressure switch.
