Question about cuttin plexiglass
aka rotten
If this is not in right area please move! I have a sheet of 1/8th plexiglass that i need to cut in 1 foot squares with angle cut out in bottem of each piece so seed will flow thru.[bird feeders] What is proper way of cuttin this stuff so it dont tear up?This stuff is expencive.Thanks Paul SORRY FOR DOUBLE POST,OLD AND DUMB,DIDNT SEE WAY TO DELEAT IT
Duker
Livingston, TX
I cut plexy quite often on a table saw using a 60 tooth or higher melamine or ATB bevel blade with a slow feed rate. You can cut it with a skil saw sandwiched in between two sheets of 1/4" plywood with pretty good success as well provided its a sharp blade and again a fairly slow feed rate.
A
aka rotten
Well 3 different ideas so far!Hell i was thinken jig saw and fine blade,I have router but never was very good with it ,didnt think of circular saw but that be hard on angels. keep em commin
A
aka rotten
It would be convenent to use circular saw for stright cuts jig for angl,but how do you slow saws speed on c.saw?Can with jig?Or you talkin about reducing push speed?
Duker
Livingston, TX
You dont slow down the speed of the saw just how fast the saw moves through the material... meaning how fast you push the saw. The other suggestions of scoring and snapping work well and you can flame polish the edges if they will show.
Duker
Livingston, TX
Duker,Ok i,ll ask,Whats flaming edges and whats involved?
Paul
You take a propane or similar torch on low flame and glaze the edge by running the torch back and forth on the edge. It smooths out the edge and clears the haze from the cut creating a nice clean edge. It doesn't take much so practice on a piece of scrap.
mjozefow
Lafayette, IN
This. I just cut over 50 pieces for a commissioned project the same way. Used seven full 4x8 sheets.
stephen4785
Benbrook, TX
I used my table saw when I made a shelf for my ps3. worked fine. I took some sand paper to the edge to give it a more uniformed look. The piece I cut was 3/4" thick.
tonym
Virginia
I always use a router..clean cut no spliter..sand it with 1000 grit and it will buff out like glass where you cut
