Question about mini splits?
rockwind1
las vegas
You can't run two "separate" rooms off one unit because there are no ducts. I bought a Della brand on Amazon, pre-charged for $800 and I'm in Houston and it keeps my 575 sq ft garage with 11' ceilings nice and cool in summer and ran the heat when it was 22 degrees and it warmed it up nicely. Mine is 110 power on a dedicated 20 amp circuit. I mounted it all, ran all electric, etc. then had an HVAC tech connect, checks lines, verify charge, etc. All in I spent under $1,300 and it's all to code.
i think they have some multi-zone units that do run seperate head units to separate rooms that run independently ( some type of variable speed motor in the compressor)
rshadd
Doylestown, PA
Mitshibishi makes dual-zone units... I went an 18k unit on either side of my garage door and used a 36k outside. Both indoor units can be operated independently. A break-out box was required for this setup. Having two indoor units was total over-kill, but offers flexibility.
Very pleased with this setup. Sure beats Kerosene.
Mini Split HVAC for Garage 2023-01-17 011.JPGMini-Split HVAC 2023-01-18 057.JPGMini-Split HVAC 2023-01-18 058.JPG
pcmeiners
"Very pleased with this setup. Sure beats Kerosene."
Mitsubishi 's warranty terms are pretty tough as to the installation.They want certified installers or the warranty coverage is void, and even then , if installed up to their standards they only cover parts.
So how do get around the warranty terms?
Personal I have (2) Fujitsu 12k units for my shop to install, warranty is very similar to Mitsubshi's. I will play their game and get EPA 608 certified .
Ps Don feel bad, I have coal
