Question about Sears jack 328 series.
mahooper84
I have a question about replacing the plunger seal in my sears 328.12001 floor Jack... This Jack was given to me but it will not stay up at all, even with no weight on it. I've tried to bleed and refill the oil and the problem still exists. My next thought is to replace the plunger seal because it appears to be leaking a tiny bit. I'm trying to avoid an entire rebuild/seal kit replacement and just find the faulty seal and deal with it. My question is, do I have to tear the whole thing down just to replace the plunger seal, or is it possible to just take the plunger out and do it that way? Any help is appreciated, thanks.
Stuart in MN
Minneapolis
Here's an older discussion about repairing that specific jack, it's in three parts:
Also, here's a general discussion about rebuilding overseas made jacks, many of them are the same thing or nearly so.
mm08822
If your situation is like mine was, all that was needed was to replace the piston rod seal and piston end cap o-ring.
Make sure all pieces of the old seal removed from the tube.
The piston rod nut required a pipe wrench with breaker bar to loosen. Protect the nut with thin material so you don't leave teeth marks. Try thin sheet metal taped to wrench jaws.
