question on wood handle screwdrivers
1930artdeco
Lynden, Wa
Hi All,
Went antique shopping yesterday and saw a bunch of wood handled screwdrivers. I searched but would like to know more about them. Is there a way to ID/age them? I saw one that was marked 'made in Taiwan' on the metal portion.
Thanks,
Mike
woody 73
The Great State Up North
Mike Hi,
You came to the right place, but my wife wants me to drive her to her appt. so I can not stay long... Yes you can date some wooden handle screwdrivers but; (always a but) it can be a bit tricky.
I have two Mac wooden handle screwdrivers but the previous owner had them in some water in there lifetime and it is hard to make out all the writing on them. (give me some time to try and take a few pictures). They were made in 1938 or maybe a year or two later, the easy way to tell the age is because they were marked Mechanics Tool & Forge Co. and later in 1945 Just Mac.
Now for you keep in mind vintage means 50 years or older so anything made from 1969 or before = Vintage. Anything from 2019 till 1970=Collectable; and anything over 100 + antique.
So odds are very high that any tool marked Taiwan is not vintage.
I have some stories about some screwdrivers (but more plastic then wood) and maybe later we can talk more about how to preserve the wood and more about the age but my wife is calling my name.
woody 73
Ok pictures as promised, but they are not my best pictures because (one), it is a round surface and( two) some rust on the better of the two screwdrivers from 1938. all marked Mechanics Tool & Forge.
I included one from after 1945 when the name changed to Mac and it is stamped from Sabina, Ohio.
So yes op sometimes you can date a wooden screwdriver, but in most cases take for example Stanley wooden screwdrivers you can get an estimate for the decade they were made and in other cases pre-war and post war for other examples.
1930artdeco
Lynden, Wa
Woody,
Thanks, that is what I was looking for. I found some wooden handled screwdrivers at an antique store but I did not find any markings on them. Except for the one that said it was made in Taiwan.
Mike
B17E1943
Far Northern Kommifornia
Sometimes the markings will be on the wood handle.
If they're not completely worn off, you may be able to get them in just the right light to make them out.
disston
Silver Spring, Md
This design and style of screwdriver was made and sold by many. They were seen as large sets of drivers from Taiwan, Japan or India. Usually cheaper especially if they were imported. They were also made by the name brand tool manufacturers of the USA as this Mac shown above.
The above screwdriver is being offered on Ebay for $40 plus shipping.
Used many of these and found most of them quit good screwdrivers. If they had any general defect common to this type it was that the handles could break off easier than a plastic or other type handle if using the driver as a prybar. And they would also break pretty easy is hit with a hammer when using as a chisel.
I know, I'm not supposed to do that sort of thing but everybody does, no?
bmwrd0
Beaver Fever Oregon
I use wood handled drivers almost exclusively. The square handled ones, as shown above, were offered by MAC, Irwin, Grace, and probably others. They are more common than you would think and tend to be marked on either the ferrul or painted/pressed on the handle. Snap-on and Cornwell also offered square handled drivers, but without the notches. As with everything else the sold, they are branded somehow.
Stanley offered many drivers in wood over the years, as can be seen in their catalogs. Rounded handles, sometimes used by Bell Systems, they are pretty common as they were offered for many years.
Plomb/Proto offered an eight-sided driver line for many years, only stopping relatively recently. Marked with either a red or blue line to denote flat-head or Phillips, not as easy to find, but a lovely driver.
Then there are the round handle unmarked one that seems to be in every old tool setup. Who knows the maker or the seller at this point, as they aren't saying. The date?
If it says Taiwan, it isn't that old, nor collectible. I see these with the handle split as they didn't use good wood that had been dried enough.
On most of them, finding the date of manufacture is the same as anything else by a manufacturer. Check the logo, is there a circle R, etc.
Johnny Generic
35 miles NE of Pittsburgh, Pa.
I don't know what the attraction is to wooden handle screw drivers but if the handle isn't cracked or broken and the shaft isn't bent, I buy it. Have maybe close to 80 right now after just 6 months of this crazy addiction. just picked up 6 drivers in their box last week but made in Taiwan, don't care.
1930artdeco
Lynden, Wa
Woody,
Thanks for all of the info. I think I can start hunting for some new screwdrivers now. Mine are good Cman but they are the cintered metal type and I would like some real steel ones.
Mike
1930artdeco
Lynden, Wa
Well went antiquing this weekend and got a few things:
A Great Neck screwdriver
A model 99 KD hack saw
An 8 inch C clamp that was made in the USA.
