acer66
Servicing the mini split would be my guess.I do not. What do you mean by servicing?
Code requires an outlet within 25’ (IIRC) for servicing equipment such as refrigerant vacuum pumps etcI do not. What do you mean by servicing?
It is only a 10/2 coming from the sub panel in the shop, so no neutral. You can not get 120 volts from this power source.I would just replace your existing disconnect with one that has also receptacle or maybe you can upgrade yours if you can run some extra wires in the conduit.
It is convenient to have a receptacle anyway imho.
Yes, you are right I was hoping that that conduit might run in a way that he can get the needed wires in the box but I have to admit I am not up to date with every post here.It is only a 10/2 coming from the sub panel in the shop, so no neutral. You can not get 120 volts from this power source.
Doubt it was ran in conduit seeing as how its NM-bYes, you are right I was hoping that that conduit might run in a way that he can get the needed wires in the box but I have to admit I am not up to date with every post here.
