Got a set of quickjacks, 5000 series. Noticed that the down button was not working so took apart handheld controller. All was good there, so thought it was relay/solenoid. Replaced those. Was originally able to lower with new solenoid as it had a bleed screw, but while cycling, one jack stayed up even with fat guy pressure on it. Air assist are charged with 50psi. Now both are stuck in up position. Took hydraulic ram and safety bar off one and still can't get it to lower. There is only the factory pivot points that could be holding it up. I hit them with PB Blaster, still will not budge. All along I thought it was the pump, solenoid or rams. Kinda relieved it may be actual jack frames... But can't get them to lower or move at all. Anyone have similar? Thoughts.
