paredown
I'm curious as to people's opinions/comparisons about a few of the "quiet" compressors on the market. I've freed up some funds from the sale of another tool, so seriously looking. Usage--small workshop, mostly brad nailers. (I'll keep my last pancake for outside work).
Contenders:
Fortress (HF) FT2135UQ: $189 2 gal, 135 psi single outlet, 2.1 scfm pump, looks to be a single pressure gauge(?), single connector, claimed 60Db, 1.2 "running HP". "panel" design, alu tank, 58 seconds to 135lb. Front panel makes it better for storage under a bench... 37.3 pounds.
California Air Tools CAT-2010A : $199 on Amazon-- 2 gal, max 120psi (?), single connector, 2.2 cfm @ 90lbs, 2 pressure gauges, aluminum tank, claimed 60Db, 1 hp/2hp peak. 35 pounds.
Makita MAC210Q: $197.99 on Amazon. 2 gal, max 135psi, single connector, 2cfm @90psi, double pressure gauge, single connector, claimed 60Db, 1 hp, Front panel (but slightly higher with roll cage) 44lbs. I'm assuming the tank is steel? Also listed as induction motor--as the others are not.
So writing these specs out shows how closely clustered they are by price/specs--and HF is not automatically the "bargain" choice.
Two wild card choices--the 3 gal Makita Quiet (+$50--2 connectors)--or (as someone in an Amazon review pointed out)--once you are there, maybe the Makita MAC 700 'Big Bore' 2HP oiled @ $214--more cumbersome shape (heavier, 60lbs), but more power, more durable, and still only 80Db--which counts as quiet compared to a pancake. The Mac 700 could be the 'one" compressor, and I could lose the pancake.
Thoughts? Experiences with any or all of the above?
Contenders:
