Quiet gas powered hydraulic pump
Jmonnty
Dowelltown TN
Does anyone have a recommendation on a quiet gas/diesel powered 7.5 HP hydraulic pump? Save wear and tear on running a piece of equipment just for the hydraulic pump.
AA/FC
Buy a gas engine, then select the correct pump for your application (displacement, pressure, flow, type, etc) connect pump and engine with a shaft coupler and pump bracket. Done.
I dont think ready-made "gas powered hydraulic pumps" are available. There are so many variables when sizing a pump/motor/use combo that it would be impossible to offer them ready-made.
Nuccio
Northern NJ
What equipment are you trying to run? Stanley and Atlas copco make hydraulic power packs.
Sent from my SM-G955U using Tapatalk
Outwest
Northwest
Are you running the pump that silencer sells currently? Silencer/moly mfg require the pressure relief to be set to a certain pressure. If your chute is portable, then I understand the reason for an engine powered unit. However, if you have already got an electric motor running the hydraulics, a large generator (12kw I think is advised) is another option. My Silencer runs off a 6.5 hp Honda powered pump from Silencer, which they offer separately if you were unaware. It is plenty loud, but with some extra hoses, I can usually place I behind a truck or trailer to muffle the sound.
J
Jmonnty
Dowelltown TN
Electric motor is hardwired at the clinic.
We need a replacement for the Honda they sell, would like a quieter pump, ET work is difficult enough.
