Joelk
I have an OLD(Made in 1957) Quincy 325 ROC 4 Compressor that makes a clattering noise. I need help figuring out what is causing the noise.
I bought it and due to the noise, I decided to overhaul it and have done pretty much a complete overhaul on it. When I tore it down I found a worn High Pressure Piston Pin and Pin Bushing and installed new pin bushings, piston pin, new rod bearings, piston pin bushings, rings and have overhauled the head. I was expecting the worn piston pin/bushing to be the cause of the noise, but it sounds the same after the overhaul, as it did before.
When I first start it up, it runs pretty quiet for 15-20 seconds, but when it starts building pressure it starts clattering/knocking and keeps on clattering until it shuts off. It seems to compress air just fine, but the noise scares me. I suppose it could be a "normal noise" for this compressor to make, but it sounds too loud to me and I don't have a known good one to listen to, to see how a good one sounds.
