Durka
Probably asking way to much IMO. It's only a single stage 60gal. Find out how much SCFM it puts out...If you can.
Does anyone know about the Leeson electric motor?
I did a lot of research on compressors about 2 years ago and went with a Quincy - 80 gallon, 2 stage upright. Not sure if it's the same as the one pictured; if not, it's close. One of my favorite comments about the Quincy -- "You don't buy a Quincy for yourself. You buy it for your grandchildren. You're just keeping it for them until it passes to them."
Scott
2 Stage, -More air, less moisture, lower heat.
Cast pump motor or no?
I think for $1900 there are a lot better options out there
Like.......?
rebaged belaire with different pressure switch and gauge.Don't rule out the HF 2 stage... It is one of the good buys at HF
I know IR gets a bad rep by some, but for $1,181 I'd buy this:
http://www.lowes.com/pd_337408-2830...entURL=?Ntt=air+compressors&page=1&facetInfo=
or the cambell that tsc has. cheaper than the IR and probably better motor.
