Quincy Compressor Fitting
mbret2004
I'm looking for two fittings for my Quincy QT-5 compressor. They are male 90 degree 3/4" X 3/4 male on both ends. One end is flare pipe thread, the other is NPT, they also have a "seat" machined inside the fitting. I can get them from the local Quincy dealer at $25 a pop, is there another place to source them that might be easier on the pocket. I'm well aware of the danger of not using quality/correct parts, like I said I'll get them from the dealer if need be.
Quincy part # 110919-024
Thanks for your time.
Strouty
Southern Maine
Are they brass, steel, or aluminum? Sounds like an easy part to get, but I would replace it with the same material. I think any local hydraulic hose place would have them.
Murphy4570
West Deptford NJ
Are you talking about an instrumentation fitting?
Not particularly cheap if so.
About $44 on McMaster.
http://www.mcmaster.com/#8239k44/=11k2kub
bigredmf
Between Boston and Detroit
https://www.mrostop.com/169ca-12-12-parker-tube-to-male-npt-brass-fitting.html
Distributor cost is about 12$ on the above
When I googled your part # there was a picture of this fitting
http://store.industrialairpower.com/110919-024-075CTX075MPX9-Comp-Elbow-Fit-T_p_13484.html
The 25$ is not a bad price if they have it in stock and you not paying shipping
It is the same as a standard high quality usa made compression fitting but it has the ferrule captive in the nut for slightly higher pressure
Red
bigredmf
That Anderson fitting is a nice high quality fitting
You might be surprised if you buy it when there is a P forged in the side
Red
