Quincy pump ID
truckdriver
Miami,OK
[/IMG]
What model is this? Seller asking $125
Thank you.
kams1973
Amarillo, TX
Does it even matter which model it is??? For $125 you better be on your way to get it.
At first glance I'm guessing it's a 325
Fixnair
Sapulpa OK
Sure looks like a 325 to me too. Rather old with that style hydraulic unloaded on the Side of the crankcase.
Best compressor under 7.5 HP ever made.
Trey T
Houston, TX
I'll pay 300 for that setup even though that motor looks like fast spinning 3450rpm.
Those Quincy pumps makes SB705 and other centrifugal unloaders types pump (curtis, champion, etc...) a POS. nothing is like those QR-25 series pump
That's exactly like finding a cheap Wilton bullet vise
jniolon
hueytown, al
there should be a data place under the air filter on the crankcase with the model number and the revision number.... I'm saying 325 also and I'm sure it's not a 310 like mine..
buy it... and drag it home... it will never leave and that ain't enough motor for it
john
TapperMan
Madison, WI
Grab it. I recently missed out on a 325 with tank and 5 HP motor for $100. Saw it on Craigslist but waited until I got home from work to call. The guy said he was tired of dealing with CL buyers and scrapped it an hour earlier.
T
truckdriver
Miami,OK
I picked it up this morning. Tag says ROC 11. I knew the motor wouldn't be any good for this pump. 3hp 3450rpm. Also picked up a nice Walker 4ton jack. Paid $150 for both. Pics coming later. Going to look at a house with a 50x90 shop now.
mharmon
Salt Lake City
Like others have said. It looks like a 325. I have a similar compressor at home that is a ROC 4. They look slightly different but close enough. Mine came without a motor and I debated what size to get. I got a 5 hp because there wasn't much of a cost difference. The 3 HP will work just fine. At lease according to this site http://www.mesaequipment.com/Html/Products/Quincy/qr25_basic.html
T
truckdriver
Miami,OK
I just downloaded the spec sheet from Quincy and they show 3-5hp for a 325. I thought you could use a 7.5hp with it, but Quincy shows 3-5. I may keep the motor for now and make sure I have the correct pulley.
Trey T
Houston, TX
Good deal on the jack but its more of a "made in USA" factor than usefulness, it's too big or long. Modern jacks are much shorter and lower profiles
T
truckdriver
Miami,OK
I actually prefer a the long form factor. I only have trucks, and all but one is 4WD, so these work better.
larry_g
oregon
Not all of us work on small cars. I'd gladly trade my modern small jack for that.
lg
no neat sig line
T
truckdriver
Miami,OK
Bought a 5hp Baldor new take off yesterday for $200. Has a pulley on it but I need to find out what size I need. I have a few 5spl motors but this true 5hp is double the weight of those and longer. It even has grease zerks front and back.
Trey T
Houston, TX
For any of those QR-25 series pump, you definitely want to get a top-notch motor. The top-notch motor to couple with that 325 is the US-made Baldor 5HP 1750RPM (not the 3450RPM).
If you got the 1750RPM, you'll need a new pulley. google RPM pulley calculator and you can figure out from there.
Another reason to use 1750RPM is if you have a vertical tank and the motor and pump sits close, you want a big motor pulley for good contact.
