I have bought a Quincy QT-5 compressor off of CL. The tank has 2 ports in the side and I am trying to remove the lower plug to at least do a visual inspection of the tank before I air it up. The plug is a 2"(?) pipe plug with 3/4" female square drive. I've soaked it with kroil for 2 days and a 3/4" breaker bar with 4 foot cheater didn't budge it so i pulled out the 1" impact. First attempt with the impact didn't do anything so I turned up the pressure a little. Still didn't turn it, but appears to be splitting the plug at the corners of the square drive. Any words of wisdom before I proceed any further? I'm reluctant to use heat on the tank and will probably use a 36" pipe wrench on what little flange is there along with the impact as my next attempt. Also, where can I find a replacement plug as my "local" Quincy dealer is 90 miles away?
