Race deck and toilet?
Blackbyrd
TN
Anyone ever installed a toilet with race deck style flooring? Attached a pic of what's going on. Tile was installed on concrete floor, I'm wondering can chizzel the rest up and but the plastic floor against the flange and re install a toilet?
CSRPenFab
Meridian Idaho
I wouldn't try to place the toilet on top of the RaceDeck tile. I think the flex might cause you some issues. Instead, do a good job of scribing/cutting the race deck to fit. It cuts easily with a jigsaw, measure twice, cut once.
The Cobbler
I would think a scribe line on the floor to mark the outer edge of the base of the toilet, cut your tile to just go past the scribe line by maybe 1/2" .fill the center area with equal thickness material, maybe some mortar or equivalent. set your toilet . many moons ago toilets were set in plaster of paris to make them sit rigid
Blackbyrd
TN
Kind of what I figured, thanks guys. I can remove one more tile without going under the toilet and **** the plastic up against what's left. Then paint the tile
goldtang
Western Australia
Once the toilet is in place I would use cardboard to obtain the correct fit and use it as the template to transfer to the tiles (CAD) cardboard aided design.
