RaceDeck Free Flow or Solid
NewYork State
Planning on getting some RD for my garage floor looking into both FreeFlow and or Solid tiles. Question is for members who have or had RD . Which tile would be better for garage where there will be snow , salt, water and other debris will get on floor.
My thinking is
Free Flow any snow and water should dry up quicker do to air flow might be more difficult to clean up dirt/ debris. Yes / No ?
Solid not much snow or water should get under solid tile and debris cleaned up easily. Yes / No ?
Which tiles would you think would be best concerning snow and water ?
Please post pictures of your design and color combo's !
Thanks in advance for reply’s. Dave
Nutty 5.0
SE PA
Free flow is what you want. It should dry faster as it has more air exposed. With that said, I used free flow where cars are and solid elsewhere.
kram71
Home
I'm battling the same decision but for different reasons. The solid is probably best for me based on use and cost but I like the look of the freeflow so it is a tough choice.
kram71
Home
Hi Nutty. Any chance you could post pics of your whole garage?
NewYork State
You can always also use both solid and FreeFlow styles in your garage floor. Thanks for considering RaceDeck... Happy New Year
1 Am I correct very little water would get thru solid tiles from seams/joints?
2 Do you recommend using fabric weed barrier between tiles and concrete floor,(solid or free flow) when dealing with garage where there will be snow from DD. Concerned fabric would hold moisture.
Blue XJ
Washington, Michigan
I have both in my garage, 2 bays of free flow for the daily use vehicles. The water and snow drip right through and can generally walk around in socks and dont get them wet. The 3rd bay is solid and it's where my hot rod gets parked and worked on. If you work on cars a lot, I would advise against the free flow. It's not the most comfortable to lay on, and good luck finding small fasteners when you drop them. My jack stands have also beat up the free flow portion, I have to put something under them so they dont sink in to the ribs.
kram71
Home
Which do you feel look better?
Which do you think are easier to keep clean?
Pics?
Garage Flooring
Grand Junction, CO
My thinking is
For high snow and water the Free Flow to TrueLock HD Flow-through tiles are awesome. Very easy to clean. Shop vac right through it. TONS of customer photos here: https://www.garageflooringllc.com/category/garage-floor-tile/
Nutty 5.0
SE PA
Good point above from @Blue XJ for laying on. It isn't as comfortable for sure however I'm using a lift so it isn't a concern for me most of the time. Small parts falling through could be a concern, but I have never dropped anything that small working on cars. I have dropped small stuff when working on a pinball machine in there though!
kram71
Home
I was leaning towards flow thru but after seeing both samples in person I may go with solid. I'm not really concerned about jackstands (use wood), snow, or small parts. I think the solid and flow thru both look good but the solid seems easy to clean and may fit me better.
CJDave
Fairfield, Ohio
As far as dropping small parts on the Free Flow, I've found that a small magnet and/or a hemostat will fish out anything that I've dropped.
Your choice should fit your intended use and whatever look pleasers you. Good luck kram71. Let us see the finished floor. CJDave.
kram71
Home
I have a magnet on a extendable rod to be a lifesaver at times when I drop things even without tiles but I think it would be perfect for flow thru tiles.
Thanks Dave. I know the tile. I know the colors. Just have to finalize the pattern. :)
