Racedeck freeflow tile colors and cleanliness
Raptor916
Going with freeflow after some help from forum members. I have a question about the colors mainly graphite, alloy and black. Does one show dirt/dust more than the other? I follow Racedeck on Instagram and I came across a picture which had 2 feet perimeter of graphite, 1 foot perimeter of black and the center in alloy. It looked unique, but understated at the same time.
kngelv
Detroit, MI
White is really the only color that ages poorly. It does not take well to grease and tire marks. You'll be fine with the ones you like. I have blue and graphite along with yellow edging and even the yellow holds up well.
James
gatorfast
FL
Alloy can show a bit of dirt mainly on areas the tires roll over. Graphite always looks consistent though.
R
Raptor916
Thanks for the replies. I basically took black, alloy and graphite in different configurations and ended up with the one below. Mostly graphite where the wheels will be.
racer1735
Canyon, TX
My floor is very similar to the red/grey shown above. It doesn't show dust much at all. The only times that it gets dirty enough to warrant washing is when a car tracks in rain or (worse) snow and its accompanying grit.
BroncoAZ
I don’t have any issue with dirt showing up on my mostly alloy floor. The light blue shows a little bit of grime once in a while, but it wipes off easily. I’m glad I went with the alloy as the primary color, the graphite would’ve turned out too dark. Graphite is the dark strip between the two different blues in the stripe.IMG_0457.jpeg
