Hi- I am very interested in using the racedeck diamond for my 1000sf garage. I have two pits in one of the bays that a lift will sit in. Is there a way to tie in the tiles to the pit? It would require some tiles sitting vertical and someone connecting to the ones sitting on the regular garage floor. Also, what do people do for the concrete lip around the border of the garage (dont know the name for it) when using tiles?
Thanks
If I’m understanding you, you 1) would not want tiles on edge vertically nor would you be able to keep them there OR attach to any horizontal tiles above or below it. That’s just not possible with RD. 2) you could just line the bottom of the pit, trench, recess whatever you wanna call it and call it good. 3) you probably don’t even need it in the bottom of the pit if the lift will fill the pit, trench, recess whatever you wanna call it.
Is this just a shallow pit say, 4-6” for a typical scissor lift type lift? If so, I would not bother tiling it, see #3 above. If it’s a deep pit like you can walk in under a vehicle, see #2 above.
