Radiant barrier foil?
Sasquatch912
Georgia
I'm debating about getting some radiant barrier foil like this below and install it on back of the OSB wall i am going to put in my metal shop. Will this be good or should i put the barrier away from the osb?Screenshot_20230515_200550_Amazon Shopping.jpg
billconner
Thousand Islands NYS
It can help a little with cooling. I believe it needs to be spaced away from the exterior sheathing, like across interior face of studs or under roof rafters. That may be your plan - wasn't sure.
I suspect normal insulation would do more but not sure.
bigdav160
Deep in the heart of Texas
If the sun hits the wall and the radiant barrier has an air space it will reduce the heat load tremendously.
As mentioned, it's not insulation but serves a different purpose.
billconner
Here's what the US Dept of Energy says, and I don't find much contradicting it.
"Some studies show that radiant barriers can reduce cooling costs 5% to 10% when used in a warm, sunny climate. The reduced heat gain may even allow for a smaller air conditioning system. In cool climates, however, it's usually more cost-effective to install more thermal insulation than to add a radiant barrier."
txvwnut
Bedford, Texas
I put something similar to that in the attic of the house, I didn't notice anything different as far as temps or energy usage but your mileage may vary.
karoc
Hemphill Tx
Several Youtubes on this subject but it’s all the guys trying to sell it
I know some people who install that foil both sides double bubble but don’t know if it was any better
lolaetype
North Western Arkansas
I put radiant barrier in our attic when we lived in the Houston area. I checked the attic temperature for several sunny days before and after the installation. Attic temps dropped by 15-20 degrees F.
QtheGenius
I've seen where people staple it between the studs with a 1-2" gap from the outside wall, then put pink panther fiberglass insulation behind it so it backs up against the drywall. Personally, I used the foil bubble version of this barrier in my garage. It's separate from my house, so I just used it between the outside stucco and the drywall. With an exhaust fan on a temp controller near the ceiling, I can be inside with the doors closed on a summer day and not sweat.
FL Guy
I just took down my radiant barrier and I’m doing spray foam.
Id sell you this if you want. I have approximately 400 feet X 4’ wide roofing foil radiant barrier available.
It is foil on one side and white fabric on the other.
I would say 90% is in approximately 35 foot lengths with the rest being anywhere from 20 to 25 foot lengths and a couple of odd and end lengths after that.
I’m in Central Fl. Let Me know.
