Rafter question
mw67rs
I am planning my future garage build. I see that many people build an upstairs room by using special rafters/trusses. How much distance is needed between the roof of the garage and the ceiling of the room for the trusses/rafters? Trying to figure out how much head room I can have in an upstairs room.
You can use Structured Insulate Panels (SIPs) for you roof and NO rafters are required.
Yes, it requires proper engineering. Yes, it will probably cost more, but you will have a strong, insulated ceiling in your "bonus room".
stingry
Western Nebraska
With a span of 40' you will need to look at trusses unless you want supporting columns or walls in the shop portion, which I'm assuming you don't. There are special trusses which allow for an upstairs room. The ceiling height of the upstairs room will depend on the pitch (slope) of the roof. Go to a truss company or your local home improvement store and they can show what is available.
Cheers
Steve
rburke65
Canfield, Ohio
Yes, you will have to determine the loader sq.ft. you will have or want in the room above the garage, the hight and width of the room you desire. Th higher and wider will affect the pitch. You can discuss this with the person at the truss company, lumber yard, or home center and they will tell you what you can do. Good luck!
mbatarga
GA
My 38' wide shop has 6/12 pitch trusses and allow for the attic storage room to be almost 8' high - 10' wide.
