Raising an existing garage?
--TRACTION--
This may be an odd question but is there a reasonable way to raise the ceiling height of an existing garage without having to re-frame the walls entirely?
I currently have a 20' x 24' garage but my full sized truck won't fit in it. That and I'd like to have some additional "head room" if I end up insulating and sheetrocking the ceiling?
kbs2244
I like raising.
It is all on the ground level work.
Not 8 feet up in the air work.
Problems are new man door framing and any underground utilities.
But 3 rows of block will get you 2 feet of waterproof wall at the bottom.
dfiler2
NW Minnesota
There is a thread here somewhere from last week where a guy posted some pics of raising his. It's really not that hard to do.
dukess396
I'm having the same problem...
If I could add to the op, at what point is it cost effective? To build a new garage on my current 24X24 footprint, would be $16k. I need enough height for a above ground lift.
lakeroadster
Central Colorado
If the only reason for raising the building is for a lift consider modifying existing rafters / trusses to be of a scissor truss design. This is especially useful if the trusses run perpendicular to the door location. Then you just modify 5 trusses where the lift is, and leave all the rest of them the same.
Food for thought :thumbup:
zcar751
Knoxville, TN
Raising a building means you are going to tear it down. You mean you want to lift or increase the wall height to allow for a bigger opening. I was all ready to suggest dynamite or a large bulldozer.:lol_hitti
sublime68charger
SW Wisconsin
Check out denwoods woody works garage for his lift makeover just a thought.
I like the idea of just adding a row or 2 of blocks under the walls to get the height that you want.
Pic of your garage will help a lot also.
jmarkwolf
Southeast Michigan
Correction:
"Razing" a building is to tear it down.
"Raising" is the opposite.
dfiler2
NW Minnesota
No that would be "razing" a building, raising a building would be lifting it.
I see someone already mentioned your error, oh well here it is again.
oldmxracer
Hell yes, it can go higher cost effectively.
Might not be Mike Holmes way !
It can be done just with lumber and siding.
T
--TRACTION--
Sounds doable and I like the idea of using block versus a stub wall. If it quits raining around here I'll get some shots of the garage. The garage is a pretty simple 20x24 and there's no utilities to it other than power but that comes up the side wall so no issue there.
Thanks for all the suggestions.
jgorm
San Diego
I did it with car jacks.
