rattle_snake's random shop projects v0.1
ntsqd
Lower left coast
It's a Tilton. Next step up would possibly be an AP. Never been all that impressed with McLeod clutches.
Maybe my standards are out of whack, but 30k seems like a short life. How much power are you pumping thru it?
R
rattle_snake
Chandler, AZ
Never heard of Tilton. What actual reason would their product be better, assuming they have what I need?
Any high HP ceramic clutch intended for racing isn't going to have a long life especially when driven aggressively on drag radials or slicks.
Car makes about 550 Tq w/o nitrous, 700 with. OEM clutch only made it 30k. I think I have used up 5+ sets of rear tires for one clutch.
I find is ironic that clutches are rated in hp, as a clutch has nothing to do with time, only torque.
ntsqd
Lower left coast
Tilton has been in the road racing and circle track clutch biz for a long time and is highly regarded. Along the way they've also become one of the go-to's in high HP desert racing. They don't rate they clutches in HP, they rate them in lb-ft torque.
R
rattle_snake
Chandler, AZ
Yes at least Tilton uses tq. Mcleod uses both now.
I guess '1000 hp clutch bro...' sounds cooler.
Looks like they have quality products.
I ordered another Mcleod RXT so I can just install it and not have to mess with adjusting the pivot/fork/linkage again. I know how it will perform and feel. They appear to only come with a flywheel now, I stayed with aluminum. Bought a Ford TOB to toss in as well.
Will I put another hard 30k on it? I dunno. Sometimes I just want a newer car but that comes with a monthly payment for a product that deprecates in value. Terminator Cobra value goes up even as I put miles on it.
ntsqd
Lower left coast
Mac Tilton is known to be a character (I'm being gentle) with a very sharp mind (& tongue). He's retired from the biz and last that I knew was pursuing his other hobby, Perazzi class shotguns.
Bolts in with little to no messing about has value.
At some point you just need/want an appliance to get back and forth. I hate that point. "Life's too short to drive boring cars" <-- sticker seen on the rear of a Celica GTS that used to pass me several times a week on the drive home in my mild pre-runner FSB.
I'm starting to think that an all stock 5.3 LS powered Vega Wagon would make a good commuter....... Probably should build the two projects inline ahead of it first, either of which will make an OK-ish commuter.
R
rattle_snake
Chandler, AZ
I need 500+ hp that hooks to get to work and back, happily. Or something like that.
Cobra is the summer weather commuter and the old trucks & motorcycles for the rest of the year.
My 1st car was an '84 Celica GTS. 22RE 5 spd. slow but impressive audio system. Did a clutch myself at 16 on that car.
Mark_17
Check the wear on the input shaft. When we dropped the trans on my friends ~800hp propcharged fire chicken, the Mcleod had a small contact area on the input shaft and it was heavily worn.
This was the same issue he experienced. We both use Monster clutches and have had really good experiences .
R
rattle_snake
Chandler, AZ
After seeing some professional level mechanic stools like the viper, I realized what a flaming pile the stool I have is. Bad knees **** and a stool can be very helpful when having to work close to the ground for a period of time. @PugetDude made a nice setup for a lot less so I figured I could trud polish mine.
The typical cheapest flimsy import junk. Had some leftover 3" casters
The casters are ****, and two had snapped off. So I did a janky repair and welded a stud to the broken stud.
The frame was 3 pieces for knockdown packaging. Solid as a wet noodle. Welded it up.
Added a piece of scrap bedframe angle to connect the ends and make a loop.
One issue with the stool is that it is too small, too short, base not wide enough. Why the casters failed. Maybe I should eat less.
So I widened the track width and strectched the wheelbase.
I also cut the corners off the casters so they don't stick out as far.
Cleaned and painted blue to go with the North side equipment. Removed the caster brakes.
Put the *** pad back on and tried it out. Rolls so much better, wow. Sits about an inch taller which helps.
Next step it to recover the seat pad, and perhaps make a back rest.
R
rattle_snake
Chandler, AZ
I should focus on finishing out the CNC router project, but I'm a little burned out on it. Last step is workflow. Pick a CAM solution, figure out the process. As a distraction, add more power to power tools.
My neighbor got this HF belt/disc sander, didn't have space for it so it's been at my shop for a long time. I made a crude stand. It works and does stuff, but not very well. The disc side is useless IMO, so I removed it. The 1/3 hp motor stall easily and in general the tool is underpowered. Happened to have a 1 hp single phase motor available, so you can guess what the plan is here. The larger motor is not enclosed, which is not really appropriate for the application but it's what I've got. My 2x72 belt grinder has a non-enclosed motor and it has lasted a long time in the rough environment.
The belt side can pivot and be vertical or horizontal. The larger motor won't fit in the same space so design is open to either configuration.
The sander mechanism in general is light duty, plastic wheels. Can't really speed it up too much or load it heavily. It came with really tiny pulleys which are not ideal in that they have minimal belt contact which limits power delivery capacity. A bigger motor pulley will increase belt speed, so decided to change the driven side from a 40 mm to a 60 mm. The shaft is 11 mm, which isn't too common, but I was able to find one. The motor/drive side will get a similar sized pulley for the 5/8" keyway shaft, 2.5" or 63.5 mm. So a minimal overdrive ratio of 5% to start with. The motor can go below or behind the main body, have to pick a path.
PugetDude
Superstition Mountains, AZ
Where are you going to put the nitrous injectors?
SMOKEYBEAR
I'd be burned out on the CNC router project as well. I've been following along as a spectator, might as well be written in hieroglyphics.
The belt grinder project here...on a dual level ( like a step) mounting surface, the motor could be located in the same position with the motor on the lower surface. The step would just have to account for the difference of the height of the two motors.
Edit, or a spacer to elevate the belt component above the new larger motor using the factory base plate in the background of the last photo if it has enough length to accommodate the new motor.
R
rattle_snake
Chandler, AZ
I haven't considered that part of the project. yet.
I've had to learn a lot of stuff on the CNC router project. Figure it out as I go.
Yup, that is about what I ended up with. (y)
R
rattle_snake
Chandler, AZ
Picked a path for the sander build. Going to keep it horizontal, as I think it is easier to build that way. I made the 2x72 grinder vertical and mounted the motor on the pole with unistrut. Didn't like it enough to do it again.
Made a design in CAD and baked in bend deductions. Some day I'll have to figure out the right way to design bent things. A simple step design, with a skirt for rigidity. 1/8" steel.
Not perfect but came out ok. I need to remember that my press brake has a minimum bend-to-bend spacing and design accordingly.
Added a flange to bolt the pole to, that still allows access to the bolts inside.
Cut a 5x4.5 lug pattern to mount the pole to a mustang wheel.
Repurposed a leg from an axle stand that already had a 2 bolt flange on it. Cut to length and made end threaded with a nut and washer welded on.
Made an upgraded workpiece rest out of 1/4 SS, tig welded. 2 bolts instead of just one.
Abandoned the sideways switch provisions inside the casting and mounted a safety switch on the outside.
In vertical configuration
Waiting on a pulley for the driven side, then need to figure out a belt and a belt guard.
R
rattle_snake
Chandler, AZ
Riding mower wouldn't start the other day, so tried to jump it with the tractor. Would start and run by die after a few seconds. The whole front end is covered in a fuel smelling goo. I just added fuel but tank is almost empty. No puddle. hmmm.
Can't put it in neutral so used tractor forks to just carry it over to the shop for diagnosis.
I removed the carb, cleaned everything and put it back together without the air cleaner assembly so I could see what is happening. Battery was shot so bought a replacement and replaced most of the terminals. Engine would start but made a lot of SMOKE. Shut it down, fuel dripping but from where? Fired again and the crankcasse vent shot a stream of fuel out.
Ahhh, engine full of fuel. wonderful. Love carburetors.
R
rattle_snake
Chandler, AZ
Drained the mower crankcase fluid and put oil back in. Cleaned up the muffler and chassis to make it easier to see what exactly is smoking. Starts and runs OK. Ran for a short time and shut down for oil and filter change. But it runs.
I pulled the carb apart and the needle and seat looked ok. All clean inside. I assume if it has enough fuel in tank the pressure will push through the float and flood the crank. The carb did come with a shutoff solenoid that leaked, so I made a 'temporary' plug, long time ago. Seems that would help prevent this issue. Maybe the carb float is intentionally set that way, engine must be running. Cheap thing to put back on, then fill fuel tank.
R
rattle_snake
Chandler, AZ
Yes I suppose I could do that. The valve is just on keyed power, supposed to prevent backfire after shut down. But it has always backfired occasionally with or without the valve. The mower gets used all year, frequently so the carb doesn't need to be run dry like other things.
zmotorsports
Northern Utah
Nice job on the belt sander Justin. Good alteration on going with the industrial start/stop switch, those are my switch of choice for machinery as well.
R
rattle_snake
Chandler, AZ
Thanks Mike. Have to be extra careful with machines like this. Can get thin material wedged under the workpiece rest, so a quick shutdown may be needed at some point. I spent way to long trying to figure out how exactly to mount it. ended up drilling holes in the base so the wires could exit out the bottom, luckily the strain relief of the box protrudes into the hole and can't chafe the cord.
Driven pulley arrived, but I didn't look closely enough at the dimensions and it is very narrow, 4 mm. Less than half the size of the other and typical 1/2 belt. Not going to work at all.
The 11 mm shaft size is kinda odd. Considering making a adapter sleeve for the driven side to use a standard and readily available 5/8 pulley.
plain2car
Gilbert, Arizona
holy cow!! Justin what a job on the re-worked belt sander!!! just the fact that I can see this stuff from guys like you, mike and pugetdude and the many others is a testament to why Ryan started this site!! ONE DAY!! even I can hopefully have/do stuff like what I see on here!! :ROFLMAO: :bowdown: :bowdown:
plain2car
Gilbert, Arizona
ohhh.. and the thought about life & driving boring cars... well I agree completely!! hence why I drive a '86 C10 LS swapped lowered SWB pickup every day.. rain or shine... although here in the grand canyon state it is usually sunny!!! ;)
R
rattle_snake
Chandler, AZ
Did another oil and filter change in the riding mower. The oil that came out was perfectly clean. Filter had some fuel in it. Uses same Motorcraft 910 oil filter as two other vehicles in the fleet. Once topped off I let it run for a short time and it smoked some, muffler had some fuel in it. Next cycle the smoke was gone and it seems to run like before. Pinched off the fuel line to make sure the fresh oil isn't diluted with fuel before I can put the shut off valve on.
R
rattle_snake
Chandler, AZ
Got the drive belt figured out and working. Bough a 3" 5/8 bore pulley at local HW store and a belt to complete the system. Makes the overdrive +20%. Couldn't find my old cut belt to measure with, so eyeballed and got a good length first try, 29". 30 seemed too natural, where as 29 is a prime number.
I was able to make a custom sleeve for the driven side to adapt the stepped 10 mm to 11 mm shaft to 5/8. Drilled a clearance hole in the spacer to align with the set screw. Pressed it into the pulley bore with press. The pulley would not fit on the motor shaft so I had used a boring bar to open it up, but too far. So used it for the other side and left the spacer a bit larger, press fit. The new motor pulley didn't want to go on either, had to hammer it on but left the bore as-is. Made a longer set screw so it would reach the flat on the shaft through the sleeve. No keyway provisions.
Decided to make a rounded end belt cover. Last one was square, which works fine but wanted to do better. Cut out a slot shape with wings to fold on plasma and used a piece of 4" pipe for the ends.
Tack welded the inside instead of fully welding, radius, slicking out the corners.
Added a mounting tab and painted a contrasting color.
Tested it out, wrong direction. Motor leads are not labeled so I removed the motor's rear cover and buzzed out the wires so I could reverse the start winding. Performance is much improved. If I intentionally stall the belt, the motor bogs to half speed and the belt slips the rest. perfect. Last step is to swap in a larger power cord.
plain2car
Gilbert, Arizona
WOW!! ... just WOW!! between the mods to garage chairs and belt sanders & the breakdowns of wypall towels & zip ties!!!! .... I am in heaven!! :bowdown: :ROFLMAO: I am serious!! ... one of these days I am just going to break protocol and invite myself over just to watch in awe!!.... :rocker:
R
rattle_snake
Chandler, AZ
Installed the fuel cutoff on the mower carb and put it all back together. But first yard cleanup and hacked the lower 2-3 feet off one citrus tree to be able to cleanup and mow under it without being a hunchback. Brutally hot now so that becomes almost dark project, but that's why the mower has headlights I guess.
Seems to run the same as before. Hard to say how bad the cylinder walls got washed down and bearing damage. It is a pressurized oiling system. I think it ran once or twice after filling the fuel tank before it showed signs of the issue. At full throttle/full load it smoked a bit at the beginning then ran clean after that. I paid $700 for the used mower more than 10 years ago, so it doesn't owe me much.
R
rattle_snake
Chandler, AZ
With mower and sander done going to tackle the clutch job on the Cobra. But have to move the CNC router out of the lift bay and make a home for it. The entire north side of the shop really needs to be reorganized. Big undertaking. Will likely do it in stages.
zmotorsports
Northern Utah
Justin, I find planning and performing regular 5S events in my shop to helpful. I try to do at least one a year, but usually semi-annually. In my last shop I seemed to work on a bunch of the same things for a season, such as when snowmobiles started coming in, I was inundated with them. Same with sand toys so I would rearrange to fit the workload and it really helped to stay organized and proficient throughout the season.
In my current shop that is harder to do because I no longer work on powersports, but I find myself with no real pattern to my workload. I work on such a wide range of items that it is harder to prepare the shop for what "might" be coming in so I have to be more mindful to keep access to a wider range of tools and equipment at all times. Fortunately, I have a little more space in this shop to be able to be flexible, but my last shop was just over 1100 square feet and much, much harder to keep everything accessible at all times.
R
rattle_snake
Chandler, AZ
5S, had to look that one up. Just did that to my entire toolbox setup, need to keep going on my material storage.
I had to move around 4 motorcycles and 5 of 8 vehicles to get my car on the lift. But everything is parked inside. Well, my stuff is parked inside. :)
zmotorsports
Northern Utah
5S; Sort, Straighten, Shine, Standardize and Sustain.
If I'm being honest, the last one seems to be where people fall off, which I find odd because if you go through all of the effort cleaning and organizing to me maintaining that is the easy part. But, I have to continue to remind my crew to remember the 5S areas and take some time to get them back in order.
A clean shop is a happy shop, especially when there's a place for everything and everything is in its place.
R
rattle_snake
Chandler, AZ
To make more room for the CNC router I decided to move the press back over by the welding table. But first, modifications.
The wheeled base for the press was an axle stand base, made of leftovers. It was deeper than it really needed to be, so I decided to cut it down so it could go against the wall better. Interestingly, it was speed metal blue before. HF toolbox casters.
Cut some hard 1/4" SS and dulled the bandsaw blade, but it still cuts straight so going to keep going with it....
Cut 6" of depth out. Touched up the paint.
Also made a rack to hold the heavy brake, instead of setting it down on the base. Used junk, some solid 20 mm linear rail for pins and 3/4 galv water pipe that rusted out. Welded washers to the press pins so they can't get pushed in too far.
Much easier on my back.
Moved the lathe back where it was, put press next to it. Bought a 2.5" hose for the little vac, as the 1-1/4 is useless with long curly chips.
Reworked the air system, removed the extra coupler off the regulator and put it inline with the ghetto hose setup to feed the AoH ram on the press, and still have a whip to blow off the lathe.
Compacted the rest of my junk and moved the CNC router over to it's new home. But no dedicated power yet.
R
rattle_snake
Chandler, AZ
And with all that moved the Cobra into the lift bay to yank the transmission. Last time it was out, I had no shop, no lift, no A/C. Every clutch I have ever done was jack stands.
Step one is to remove the shifter. I seem to remember thinking it wasn't necessary only to remove it after fighting it. So just pull it out and make a cover. I found a plasma cutout from '72 F250 door panels that was the perfect size already, and with radiused corners. Drill some holes and done.
The shifter pedestal sits high hence why it won't move back much with shifter installed. Keep debris out of trans.
Done on the top side, interior.
I unplugged all the wiring and removed the exhaust h-pipe before calling it a night. One manifold bolt requires a 15mm deep swivel socket. Nothing else will work. But I have a set as I have been down this path before.
fouckhest
Greer, SC
I like that press stand and really like the storage spot for the brake, I am going to borrow that idea from you an retrofit my press.
Thanks for sharing that.
R
rattle_snake
Chandler, AZ
Sure, glad it is helpful. Brake is heavy and I seem to use it exactly 50% of the time, so it gets moved a lot.
I was going to add some more storage solutions for various pipe, pucks, blocks and so on, but just moved it back over to where that stuff already was.
