WoodsTruck
- Joined
- Jan 12, 2013
- Messages
- 1,038
Thanks. The Zuk is a 96' 250cc 4x4 my buddy picked up for $1000. For the money it does everything it needs to do. Please share the mods and I will pass them along to him.
There is a lockout pin above the center shift cluster. The superlow/low/high and 2wd/4wd pivot on the same bolt/shaft. Above it is a pin that slides so when you are in superlow the front diff lock can be activated. If you pull the cluster apart and remove the pin, diff lock can be used in any 4wd range. On my King Quad this was super handy for using low range in the snow or mud to keep momentum up and traction high. It also allows shifting in and out of diff lock easier as the pin doesn't have to move every time.
I also connected into the neutral safety switch with a rear brake switch to allow the engine to be started in gear. I have to press down on the foot brake where the switch is mounted in the supplied tab. This makes it super nice if you get hung up in a ditch or over a log and the engine dies to simply apply the brake, start, then continue on. Other manufacturers do it this way as well. I should have installed a diode in the system though but it works great for me.
I have done other things to it but those are the two that really made a huge difference.
