raw gear stock
whateg01
doo dah, kansas, usa
I'm trying to find some gear stock in a 16 dp, 32T. I need to confirm pa, but so far, I can't even find a place that stocks anything lower than 20 dp. Anybody have a source for this?
Dave
Firebrick43
West central Indiana
If you want a bore able hub then Martin has s1632 for 14 1/2 pa and ts1632 for 20 pa
I am thinking though what you want is pinion wire? If so it is not available in any thing bigger than 20dp as its a cold drawn material and the forces get to large.
Falcon67
Merkel, TX
I was going to say Spacely Sprockets, but I think - when I was in mfg - most of our gear stock came from Boston Gear.
W
whateg01
Thanks for the replies. What I have found is that I can get spur gears in that size, but they tend to not fit all of my requirements. Specifically, I need to be able to press a dog clutch onto one side and leave a small hub on the other. I have't gotten the machine apart yet to know exactly how long it all has to be, but it's in the neighborhood of 1.5", I think. I did check Boston Gear and SPI. Several places have pinion wire, but yes, it does seem to go up to 20DP. It seems that once you get above a certain diameter, they stop calling it pinion wire, but the DP still doesn't get any better for me.
I have been spending a lot of time on the Monarch forum over on PM lately, having just picked up a 10ee that needs some work, so I'll ask there, too. I can cut a new gear, if I have to, but if I can get gear stock that just has to be cut down, that would be much easier.
Thanks!
Dave
Firebrick43
Can you machine the hub portion and cut out the hub of a standard gear for a shrink fit? After the ring is shrink fitted on drill and ream a hole for a dowel pin to lock it all together.
jbfab
Have you looked at McMaster Carr?
Sent from my SM-T320 using Tapatalk
matt_i
In a 10EE there are no 20deg PA gears. All 14.5 deg PA.
The most important feature of a gear is that the ID and OD run concentrically.
When you learn the OD if you have bore-able pie-style soft jaws for a 3 jaw chuck this is the best idea.
If its made by Boston or the like with a pre-bored center, you can indicate the center hole in a 4-jaw chuck to maintain the same concentricity.
W
whateg01
Yeah, I can do all that. Most of the ready-made gears don't have enough hub to hold the ring, though. I believe I also need material on both sides of the gear.
This isn't from mine, but is what I need to replicate with a smaller bore.
Yep. No luck. They don't stock gear stock (at least I don't see it on the site) and the standard gears don't seem to have the dimensions I need.
Like other places, they stock gear stock up to 20DP, but nothing numerically lower.
Thanks, Matt! I did find, after more reading, that yes, they are all 14.5 PA. I may have to have a gear made. It's not the end of the world if I do. Of course, if I do have it made, I can have it bored and broached, too. I'm tossing the idea around in my head of buying a set of cutters, but I know I am not likely to turn out as nice a gear as if I get it from somebody who has all of the equipment to hob one correctly. And how many gears would I have to make for the cutters to pay for themselves?
