whateg01
I'm trying to find some gear stock in a 16 dp, 32T. I need to confirm pa, but so far, I can't even find a place that stocks anything lower than 20 dp. Anybody have a source for this?
Dave
Dave
Can you machine the hub portion and cut out the hub of a standard gear for a shrink fit? After the ring is shrink fitted on drill and ream a hole for a dowel pin to lock it all together.
Have you looked at McMaster Carr?
Sent from my SM-T320 using Tapatalk
In a 10EE there are no 20deg PA gears. All 14.5 deg PA.
The most important feature of a gear is that the ID and OD run concentrically.
When you learn the OD if you have bore-able pie-style soft jaws for a 3 jaw chuck this is the best idea.
If its made by Boston or the like with a pre-bored center, you can indicate the center hole in a 4-jaw chuck to maintain the same concentricity.
