Hello
So the story goes that I used Rustoleum Epoxy shield (water base) on the floor in my garage. I also clear coated. Now I’m not having trouble with peeling or anything of that sort. Surface prep was immaculate if I do say so myself. The issue lies in the face that I have some minor cracks that are showing through and also a couple of spots on the floor that didn’t get covered all the way. In short, it is just bothering me.
My question is what needs to be done to floor in its current state so that I can lay down Rustoleum Professional 100% solids epoxy. and I also want to clear coat. My plan is to lay the epoxy down pretty thick so as to cover the cracks that are showing through.
I have a floor buffer at my disposal with all the assorted pads, and also a pressure washer if needed. I can also rent equipment if it is necessary.
Pleas let me know your suggestions.
Thank you,
Yodash89
Thank you,
Yodash89
