Re-purposing a hand-drill drill press?
jmarkwolf
Southeast Michigan
Found this Craftsman drill press "adapter" in a dumpster recently.
Don't need a drill press, already have several, and a Bridgeport, but I couldn't let it die a horrible lonely death.
Any ideas what to do with it?
nine4gmc
Dallas
Put it on CL for $100 and bump the listing once a month, that's what someone here does :lol_hitti
Seriously though, I'd try the dremel idea or maybe a rotozip...
jakemac
New England
I don't know if it will work with that machine, but .........
I have a similar set-up that was a small belt driven drill press. I put a leather punch in it and used it to punch holes for stitching through thick leather. I used a chisel type punch, not a hole punch.
(no pictures, it's buried in the back of a storage unit now)
Scimonetti
VT
Only once a month? My guy has made several postings for it and does it as much as possible!
Thumper68
Duluth MN
If you don't have a mag drill or if you need to drill a straight hole in the center of a large sheet you can clamp it down and use it.
I had to drill a few holes in a large plate, 350 or 400 lbs, no way I was going to lift that onto my drill press not to mention it was about 20 inches from any edge so the press wouldn't have worked anyway, I put the Mil hole shooter in a similar rig and clapmed it over the spot, made a ver serviceable hole.
wild cowboy
Birmingham
yeah, sad to say, that this is worth basically the aluminum melt value, given the fact that you can get an actual drill press for $52 at harbor freight with a coupon, most people can afford that.
Joe B.
I would just put it away and remember you have it. I'm sure there will be some strange day when you need it to prop something up or hold something.
panknuckshovel
Land o Lakes FL
Find a hand drill to put in it. Find an old spoon that you can grind the width of the handle down. Put the spoon in the chuck and turn it into a garage cocktail mixer.
Uncle_Charlie
Rogers, AR
I have one of those with the original drill in it. The drill needs a new power cord to be safe to use. There is a woodworking tool (the name escapes me at the time) where a chisel is mounted in a similar device. It's used to clean up a slot that is rough cut in the wood. Basically the chisel is plunged into the wood, the wood is moved slightly and the chisel is plunged again until the slot is clean.
Scimonetti
VT
It's called a hollow chisel mortiser. I don't think this would work for one, but maybe some sort of light press though.
Beemer533
Syracuse, NY
get a drill to fit and make a dedicated stirring machine.
I like that idea.... Put a small metal paddle on it, sharpen the blades and use it in the kitchen to make smoothies and milk shakes:D
I've actually got one these as well that I inherited from my grandfather... It still has the original drill in it.
jakemac
New England
cut down a paint stirrer :lol:
T45
Dream version... :evil:
Outlander
Quebec, Canada
I have some spare tools (ya right) that I plan to donate to a local FIRST Robotics team in a needy area. They had tools stolen last year. Maybe there is a local organisation near you that could use this?
larry_g
oregon
x2 on this. I keep one for just this reason though the one I have is 3x the size and fits my Sioux 5/8" drill.
lg
no neat sig line
MadMark
New York City
what about a tapping station?
Enco and MSC sell them.
i've used them and if you have a lot of hole to tap, it's faster than chucking the tap in you Bridgeport.
nine4gmc
Dallas
You guys are over thinking it, hit some garage sales this weekend and I bet you'll find one of these for $1 or so...
Fugio
I keep an old drill in one with a 4" wire wheel. Makes removing rust from round things (like bicycle wheels) REALLY easy!
Bobf
Poway, CA
I'm with madmark. I found the same stand at a swap meet for $5 and made a tapping station out of it a couple years ago.
