Kevin wrinkles
- Joined
- May 12, 2011
- Messages
- 2
I need someone who can get a rebuild kit or someone who will rebuild it at a affordable price it is a walker g874
Very Nice Thomas...![]()
have accuired an Old walker jack..?? was told it was sent out to be repaired?? returned and will lift with no weight, but will not under a load...???... where does one start with what is needed.. its a nice jack and want to restore it..
There is a thread about rebuilding a WALKER 93632 on GJ. Take a look at it so you have an idea of what you are getting into. You will need to fabricate a special tool to remove the tank nut which, by the way, is tightened at the factory to 200 - 250 ft. lbs. So, if you have a good impact tool, you will have no problems.
Do not use a pipe wrench to remove this nut as this will damage the nut's edge that seals the oil tank. This jack jack does not use any type of sealing washer between the tank nut and the oil tank or between the tank and the pump body. It is a metal to metal seal and that is way it is tightened to the above mentioned torque figure.
Also, do not try the punch and hammer way as this will only damage the nut's slots and you will need to generate at least 200 ft. lbs to remove the nut. If you were so lucky as to remove it with a punch and hammer is only because the jack was repaired before and the nut was not tightened enough during the repair.
Below is the link.
http://www.garagejournal.com/forum/showthread.php?t=80165&highlight=jacks
Hiball, I did not say it was repaired recently, or ever, so it could actually be an u-cup issue. I was only refering to the ease or difficulty in removing the tank nut by using the punch and hammer method.
This body style is pretty old and if it was fitted at the factory with an urethane u-cup, you can bet it is a broken u-cup as these do not last more than 12 to 18 or so years depending on usage. An u-cup in an old jack that is seldom used will harden sooner, become brittle, and break easily afterwards. A jack that is used frequently will last longer as the usage keeps the u-cup flexible for a longer time. Anyway, both u-cups will eventually break, sooner or later; there is no escaping that fate.
Hi Hiball
I just bought a sweet Walker 884 Series B and don't know a dam thing about it. I am looking to refurb it but am not 100% what it needs. The jack works somewhat and I don't see any leaks as of yet. The arm will lift up but does not have any power once you put it under a car. (Could be as easy as topping off the oil but again I don't have a manual.) Is there a process you can recommend and also if I do replace the seals do you still sell rebuild kits? Anywhere I could get a manual? Thanks in advance for any help.
Eric
I have an old Walker Model J-134 series AA that works (or worked til I broke it) great old 4 ton but I broke the "cap housing" I think what it is called, the part into which the cap or cradle is put into. Been looking every where on line for the part, can't find it. Managed to find a picture of the manual from the 1940's or 1950's. Another parts blowup picture of a Lincoln 4-ton called it a model 93657. So any one know where I can get parts? I'm in KC, looking for Hi-ball to get back with me - I hear you're the expert in this Hi-ball.
I am looking at walker jack but can't find a name plate on it. Leaks oil and comes with a 4 liter pail of oil. suspect just needs new seals in the ram. anyone know what the model number might be on this jack so I can get some parts for it. I would like to restore it back to original or close to original.
I have a walker model 767 series A floor jack looking for cylinder rebuild kit and instuctions. Was mentioned walkers are blue but this one is red and best I can tell it was never repainted.
Hello all,
I'm new to this site and have read that a guy named "Hi Ball" knows Walker Jacks. Well I have a Model 882 "Roll-A-Car" floor jack. What I need is a rebuild kit and some basic info on to the rebuild. I am hands on kind of guy and like to fix things myself. I have most tools found in a shop and I think I'm pretty good at fixing things.
Thanks,
Since this seems to a be a good ongoing good thread on these....
Just picked up from our state surplus property office a Lincoln 10 ton jack. For $20 I could not resist.
It's been painted over at some point in its life and currently is only useful as a narrow cart. It will not raise up at all.... I'd going to tackle rebuilding it as it seems to be good, solid, serviceable and just in need of some attention. Both tags were painted over and in poor shape but I've managed to carefully remove the paint and can tell you this much. Model is a 93660, the pump casting #234342 and the tricky bit which is the most difficult to determine is the series. As best as I can tell on the one tag it looks to be a series C. Serial number is a riveted on metal tag instead of a stick on aluminum tag, SN# K660A12045. I saw some rebuild kits on the web, some show different kits for different series while Blackhawk just shows one kit.
Regardless it looks as though Hiball might be the best option as I'd always prefer to do business with someone who is helpful on forums like this. Shoot me some info on my jack Hiball.
Couple of photos (I do have the top cover for it). One showing the whole jack along with other projects in the background like an older JLG scissor lift, and a 1985 Clark forklift I recently got running. Second is a shot of what is left of the better of the 2 tags on the jack. Not much to work with there.... I'd like to find good clean photos of a label for one as well as the other labels. I have a sign company so I'm going to ultimately make new decals for it.
heh guys, i have a walker j134 series floor jack, it raises , but will not hold more than couple hundred pounds. i split the jack in 2 and got the hydraulic ram apart, and cleaned the inside. piston and cylinder wall look fine.refilled with hydraulic oil and still wont hold load. what do you suggest from here?
I have a wonderful, old, large 1950's era 4 ton Walker floor jack that is leaking fluid. I have had limited success trying to find a rebuild service kit or a business that will rebuild it for me. They all said to just replace the whole jack which I will not do. My feeling is cost is not a factor. It lasted many years and I expect it will do so again if rebuild properly. Has anyone had any experience or advice along a similar situation? Thank you.
Thomas
Go to this place, a complete kit will cost under 40.00 with instructions and a diagram for special tools if required.
http://www.iserv.net/~wmogrady/lube/jack/lincoln/lincoln_walker_rep.html
