Recent machinery additions to the workshop.
William Payne
Wanganui, New Zealand
I will eventually figure the best place to have a dedicated workshop thread but for now will show off my most recent purchases here.
I’m still getting stuff home so these pictures are from before they arrived at home.
The welder and drill press were purchased close together. The grinder a few weeks after.
matt_i
Great stuff, I really like the side-slots on the drill press.
A Sync will give you many years of good service :thumbup:
W
William Payne
I also this morning found a smaller bench grinder that I forgot I had. Was hiding under a bench under some stuff.
I have this strange habit of forgetting I own things.
W
William Payne
I still need to get some kind of saw, a bigger air compressor, a, and a linisher and an oxy-acetylene setup.
Once I have that stuff I feel I’ll be able start working on things.
bl00
Chantilly, Virginia
When you get the drill press home could you post some close up photos of the power downfeed? I have the same drill, but without the downfeed. I might make one someday if I run out of things to do.
zmotorsports
Northern Utah
That drill press is beefy as hell. Table could use a bit of work but I like the vertical mounting surface it has. Never seen that before.
You'll love that Miller Synchrowave. Solid and dependable machine.
All are great additions to your shop.:beer:
dutchgray
Dorset. England.
Nice pillar drill, Startright EFI I believe, with power feed so very useful, the most versatile type of table, which is seen on several European makes, probably around 800lbs of quality you can't get anymore.
Even though I own a 4 spindle gang drill, I would still pick up a drill like that if one came up locally for the right price.
dr_clyde
Holland, MI
This is what happens when you work in a shop a long time and want to have the same quality of equipment when starting your own shop.
That is the problem with using nice gear. You realize how much nicer it makes working in the shop and after a while you don't want to use anything else.
Nice tools. I love my Syncrowave 350. I have a Startrite cold saw, and if your drill press is anything like my saw, it is built very well.
W
William Payne
I’m thinking about repairing the table but honestly it’s purely cosmetic except on the side. The table top is still perfectly usable and honestly after years of using drill presses most of the time I’m using a clamped vice anyway.
W
William Payne
Everything to wire in the Syncrowave was big and high amperage so had to be special ordered and with it being the holidays the electrician was still waiting on the circuit breaker.
It is wired to allow full use of the machine. Will be able to use the full amp range and duty cycle. I also have a new Coolmate 3 cooler to go with it.
W
William Payne
just to ask............. what kind of power you guys use down under?
Single phase is 230-240v 50hz. 3 phase is 400-415v 50hz.
I had 3 phase installed on my property at my own expense.
I have seen phase converters advertised in the odd magazine but I don’t know anyone using one down here. Anyone who genuinely has a use for 3 phase either has it or gets it installed. All the utility poles are wired for it you just need to pay to be connected to it.
