recommend an induction heater (for bolts) please
rust in the eye
Chicagoland
Having recently broken a hard to access for repair rusty stud I've decided to buy one of these devices.
I've used a borrowed one in the past and know what a life saver they can be.
The one borrowed was tool truck bought at $$. All the ones I've looked at appear VERY similar and invariably imported so my immediate thoughts are to use price as my primary criteria to choose.
What are the thoughts of those here using them and are they all pretty much created equal?
zmotorsports
Northern Utah
I have the older model of Mini-Ductor that has worked well for me over the years. It gets used, but nowhere near as much as I thought it would when I purchased it.
R
rust in the eye
Chicagoland
I have a bolt-buster 2, have been very happy with it for several years.
This, I believe, is the one borrowed. Made not only in USA but a half hour drive from where I sit.
expensive but........
EDIT: tried calling them to order and all phone #s are either disconnected or one was an individual's voice mail with no reference to what company I may have reached.
looks like Chinesium in my future
zendriver
Indiana
If you'd rather not have "Chinesium" try this number
2ndGearRubber
Pittsburgh
I don't think they sell direct over the phone.
I got mine sub $400 with coils bargain hunting, maybe 5 years ago. I think Napa had it and I waited for a coupon online.
djbmw
Ottawa, Ontario, Canada
I bought a Chinesium one several years ago from Amazon (arent they all made in China anyway?).
The "JWGUTS Magnetic Induction Heater with 10 Coils and Case". It has served me very well!
I paid $336 CAD which is $237 USD at todays exchange.
djbmw
Induction Innovations products are all made in Illinois.
Thats not true. Induction Innovations sells the same "made in China" products as everywhere else... but with their brand name slapped on it. Look at the Country of Origin on most of their tools.
The ICT-MD-700 specifically states "made in china".
mreisner
North of Detroit
Where does it say made in China? I know when I bought mine a couple years it said made in USA. Perhaps they have changed?
R
rust in the eye
Chicagoland
Thanks. Another outfit in my back yard. Must be something in the water around here. I'll investigate.
No reply from e-mail sent to bolt buster folks and 2 phone #s are disconnected, yet these remain offered by a bunch of sellers. I don't figure I could count on much support if I did buy one.
zendriver
Indiana
Other than a usually short warranty, not sure what other support you would ever need. :dunno:
It's just basically a power supply, energizing an induction coil made from insulated copper wire. It either heats or it doesn't. There is a YT vid with an imported unit tore apart. Looks like $40 worth of electronic parts.
Even USA made not sure why they cost $600 :headscrat
If mine craps, I'll just get something else. They have a relatively short duty cycle, so I use mine gently. I wonder if just like welder problems, people use them too long and they overheat internally.
djbmw
You have to use the WayBackMachine for quick info. Induction Innovations products used to be 100% made by Smithermal Co., LTD out of Chengdu City, China Mainland.
Today, Induction Innovations "assembles" the units in the USA... but they are the same Chinese induction heaters that everyone else sells, just at 3x the cost because a north american screw driver tightened the screws.
pbon
$385 on Amazon today
pbon
Was $385. Dynamics pricing may have pushed it up at some point in the day.
zendriver
Indiana
WWheeler
Middleofnowhere USA
At least they sold that one in a cool-looking plastic case.
Mine looks like it came from "Band Camp!"
FWIW for the true cheapskates, there are a zillion plans, kits and parts to build your own.
I'd trust your style of case will last a lot longer than that plastic one.
It's been my experience that major brands like Dewalt and Milwaukee still know how to make a clamshell plastic case that's durable AF, but all the chinesium cases I feel lucky if they don't arrive broken, but even if they did they don't typically last very long or survive much use at all before they are.
Steve_P
Can the bolts or nuts be used again after they are heated with this thing?
Technically yes, as long as they're still functional. But depending on the application, they should be replaced as exposure >400F can change the strength properties due to changing the original heat treatment.
bigtater
utah
Yeah I worry about them losing their strength. I am thinking about getting one for the farm as many nuts get rusty due to contact to the elements and ground. I guess I'd have to always remember to probably not use it on critical connections.
IS the bolt buster a good one?
Bmw4life
Canada
This is the most powerful tool I found.
Will test it shortly. I bought it because I'm going to heat the crankshaft bolt.
I couldn't remove that bolt with dewalt most powerful 1/2 impact, DCF961
If this tool works, then it will work for any other bolt on the car.
The problem is, these tools are limited to 1800w due to north American outlets being 120v. So the math is 120x15=1800
I wanted to buy a more powerful tool, 2000w or 3000w, but couldn't find much at all. My guess is that's because they wouldn't work on standard outlets, so no one manufactures them.
swsman
Earthbound
Which vehicle?
Do you have space to work with bracing a breaker bar and socket, then just turn the ignition key for a short crank.
I have removed crank bolts with this method before.
There is also this tool, it is made by a few different manufacturers.
gizardlizard
Madison, WI
No reason at all to be heating a crankshaft bolt. Are you using a weighted socket?
R
rust in the eye
Chicagoland
Given your screen name I'll assume this crankshaft bolt belongs to a BMW. Unless your engine has been underwater for years corossion isn't your problem. They are just VERY tight.
All the heat you are applying isn't good for anything, especially the seal.
Get a stronger impact or a long, strong breaker bar.
Bmw4life
Canada
Haha yes the engine is N62B48
I was told by a couple of mechanics who work on engines that heat will do it. Not because of corrosion. I thought heating a super tight bolt will help loosen it. Maybe not?
The seal will be replaced either way
Steve_P
An oxy-acetylene torch will definitely do it- BTDT. Haven't tried propane since I have OA. Basically, you are just lengthening the fastener due to thermal expansion which then lessens the preload- and the torque required to remove it.
signcrafter
Yeah, that would be an instant "one and done" bolt if heated.
Order a new crankshaft bolt before you take it off.
Most crank bolts are one time use now a days so getting replaced anyway. I've had to use heat on them, the large diameter flange/washer on them gets fused and don't like to come off. Yes I have weighted crank bolt socket set and big impacts. You usually don't have to heat them up much, just enough to break the **** bonding them. And the nice thing about the induction heater is it heats just the bolt up fast so the heat doesn't get transferred to other parts.
Hakeem
Chicago
So THATS how it works! I’ve heard maybe half a dozen explanations on how heat will facilitate the removal of a stubborn fastener but none that ever made sense to me. Is this also how it works to free a fastener that’s rusted/corroded in place?
Bmw4life
Canada
Nope just a regular one.
I was supposed to get the tool today, but Amazon now says it's delayed by 7 days :( may just grab a 3/4 breaker bar in the end
