Recommendation for 1/2 inch Corded Drill
bookman51
Kearney, Nebraska
My cheap Harbour Freight corded 1/2 inch drill bit the dust today. I had not used it much. I thought I would splurge on a good quality 1/2 inch corded drill. I am a home handy man but with a shop with several tractors and implements. I have a drill press for heavier stuff, but everyone once in awhile I find the need for a heavier duty corded drill to drill through metal for which I can not get to my drill press. What are the recommendations? Probably do not need a high end contractor model, but a good one that will last occasional use would be nice. I thought the Harbour Freight might be the ticket but it played out too quickly with occasional use. Thanks in advance.
mike93lx
Richmond, VA
I have the now-discontinued d handle low speed drill from harbor freight that I use for mixing thinset, grout and drywall mud. It's worked great through a bunch of projects, but isn't used frequently. This is their current version
Which one have up the ghost on you?
sparky 1971
Central Iowa
I have a couple of Milwaukee corded 1/2" drills. They haven't been touched in years, but I used to use them regularly and they performed flawlessly. Which one depends more on what your drilling and how large of a bit.
I have this, it's 700 RPM but there is also a 950.
This one has run more than it's share of 1-1/8" step drills through panels as well as drilled out many houses. It's a 900RPM but there are also 450 and 650 available.
ebay is loaded up with both, get one of each just for the sake of being a Garage Journal member.
I am going to be fabricating some shelves for my shop in the near future. I may have to break these drills out as well as my Bosch Bulldog rotary hammer just for nostalgia.
mark-NJ
new jersey
Do you need the power of a 1/2"? Or just the chuck size?
I bought an 8Amp Dewalt 3/8" and put a 1/2" keyed Jacobs chuck on it. It serves my needs 100% and cost a lot less than a 1/2". It's got enough torque to do everything I've asked of it.
goldtang
Western Australia
Avoid the new AEG I bought one a couple of years back for steel it was ok , had to use the hammer function did 10 mm by 75 deep holes in concrete about 80 off , then went to landfill
dogdog
Same I have that grey one and works on mixing drywall mud no issues, as long as I don’t use a giant paddle, just a small and mid size.
used it to drill bolts, these low speed high torque drills works well.
When I was looking, I did consider the ridgid heavy duty drill mixer
Or almost every brand have a hole hawg drills that are also 1/2”
MushCreek
Upstate South Carolina
I still have my old (40+ years) Milwaukee Hole Shooter. I've used nothing but Milwaukee cordless for the last 12 years or so, though, including building my house. Buy a good cordless, and glue a cord onto it. If you really want corded, I agree with others; look for a clean used one. I have a corded Milwaukee SawzAll with about an hour's use on it. When I get around to selling it, someone is gonna get a good deal.
KnurledNut
n/a
Regular 1/2 drills are usually limited to 700-1000 RPM.
This is fine for bigger twist drills, but a 3/8 is better for smaller sizes that benefit from more speed.
A 1/2 hammer drill with rotation-only and speed-selection gives some benefits of both, commonly running up to 2500 RPM. The trade off is added size and weight.
I have both Milwaukee and Hilti 1/2 hammer drills.
In 3/8, a Milwaukee hammer drill and Bosch regular.
Beauregard
Southern Nevada Desert
Milwaukee Magnum is the standard for 1/2" corded.
Quality chuck, powerful motor, and good ergonomics.
For some reason, a lot of these got pushed to the back of the box with the cordless revolution. It's still my go-to in the shop when a lot of repetitive holes in thick metal in tight places need to be drilled. Yeah, we still use a drill press or cordless when called for.
They can be found used on Craigslist, FBMP, or estate sales for cheap. Corded tools seem to have little value these days.
dnschmidt
Phoenix, AZ
Can't really go wrong with any of the major manufacturers. I've got at least a dozen corded Milwaukee, A couple true Metabo (not the rebranded Hitachi) A Black and Decker Industrial (which they renamed DeWalt) and a BOSCH. All work fine. The comment to look used is probably the way to go as I haven't used a corded drill in forever and if I ever sold mine I'd probably get pennies on the dollar in spite of the fact that they are nearly brand new. A LOT OF PEOPLE HAVE CUT THE CORD and basically great corded drills should be a dime a dozen on the used market. The sole exception might be mud mixers which still tend to be corded although cordless versions are made by Milwaukee, DeWalt and I believe FLEX.
bookman51
Kearney, Nebraska
Mine was model 61741. it said "heavy duty drill 0-1200 rpm, 6.3 amp. Chicago Electric
Ben Buck
S. W. Ohio
I have 2 Milwaukee’s 0234-1.
Quality units, not used that often- but when needed they do the job.
Rinspeed
NY
I agree on the Magnum.
finn
The UP, God's country
I have a right angle Milwaukee and a Craftsman Industrial. Haven’t used the Milwaukee in years, and finally pulled out the Craftsman to mix some grout and scratch coat this fall.
I wouldn’t even consider buying, or recommending someone buying a corded drill at this point.
I consider corded drills obsolete.
Corded grinders, yes, but nothing else
bookman51
Kearney, Nebraska
I only do occasional work and then in my shop, and it is a real pain to keep up on the batteries for tools. I have a collection of batteries that have been rebuilt several times, and I have been slowing switching back to corded or gas tools. Sure, battery tools are handy, but also batteries are pricy. I recently looked at getting a battery powered chain saw and decided nope. No doubt I am in the minority.
finn
Are your tools Lithium? Big technology improvement over NiCad.
seber
Deep East Tx.
Milwaukee Magnum Holeshooter was industry standard forever until cordless came along. They just can't be hurt. I have one that was used for stirring asphalt until they couldn't work the trigger through the mess. Cleaned it up and used it ever since.
bookman51
Kearney, Nebraska
Yes, Lithium is a big improvement. I have corded and battery impact wrenches and drills. When I want mobility, I go with the battery ones. When I want power and durability on a job, I go with the corded ones. I am sure if I were building a house, i would go with battery. However, I am working in my own shop and never far away from a plug in, plus, if need be I do have a portable generator.
908Jim
Look for a good quality used 1/2 Milwaukee Magnum "Hole Shooter" drill. Replaceable cord, USA made, and 0-850 RPM speed range with an excellent variable trigger and more torque than you'll probably be able to control.
bookman51
Kearney, Nebraska
I finally purchased a Bosch 1/2 corded variable speed hammer drill at Menards on Friday. It was on sale for $79. Yesterday I did not get even two holes drilled in 1/4 steel before the variable speed quit. I took it back today, and they gave me a full refund no questions asked. Now I am looking at the 2 speed, MasterForce 1/2" two speed drill. Not high end but I need something I can use occasionally to drill through 1/4 steel that I cannot put on my drill press. Only $89.88. Thoughts?
sparky 1971
Central Iowa
To be honest, from my experience, hammer drills don't do anything well. The RPM's are too high for them to have enough torque to drill through anything remotely close to tough, and other than concrete block, don't hit hard enough to drill masonry. If I was limiting myself to Menards, I would go with one of the D handle mud mixer type drills, preferably the Bosch but if $190 is out of the budget, the Masterforce for $80 is better than a hammer drill.
