roofdweller49
- Joined
- Jan 22, 2023
- Messages
- 186
Yeah anything bigger than 1/4" - SDS time
They do great for brick and block. Most electro pneumatic drills will chip those too much to get a clean hole. Only my little tiny m12 sds drill is light enough to not chip those too muchTo be honest, from my experience, hammer drills don't do anything well. The RPM's are too high for them to have enough torque to drill through anything remotely close to tough, and other than concrete block, don't hit hard enough to drill masonry. If I was limiting myself to Menards, I would go with one of the D handle mud mixer type drills, preferably the Bosch but if $190 is out of the budget, the Masterforce for $80 is better than a hammer drill.
A hammer drill doesn't work worth a pinch of **** on most brick. I've used enough to know, including a 3/8 Milwaukee, 1/2 Milwaukee, 9/16 Makita, and various others that were supplied by employers. The last time I used a hammer drill on brick I got so pissed off that even though it was a company drill, I threw it away and bought my first SDS. I will admit that some brick can be drilled, but that brick is soft enough that a regular drill with a masonry bit will do the job.They do great for brick and block. Most electro pneumatic drills will chip those too much to get a clean hole. Only my little tiny m12 sds drill is light enough to not chip those too much
A hammer drill works great on brick and block. Been there done that so many times I can't count.A hammer drill doesn't work worth a pinch of **** on most brick. I've used enough to know, including a 3/8 Milwaukee, 1/2 Milwaukee, 9/16 Makita, and various others that were supplied by employers. The last time I used a hammer drill on brick I got so pissed off that even though it was a company drill, I threw it away and bought my first SDS. I will admit that some brick can be drilled, but that brick is soft enough that a regular drill with a masonry bit will do the job.
Anyway, the drill that is needed in this thread is for drilling metal up to 1/4" thick and a hammer drill does a worse job with that than it does brick. I just threw in an extra reason to not buy a hammer drill.
If you go back to post 40, I already said hammer drills are ok on concrete block. I stand by my statement that they are useless on most brick. Maybe you've only encountered the soft brick, of which I've been able to drill into with a masonry bit and a regular (non hammer) drill. The merit's of a hammer drill in brick and block don't matter in this thread anyway. The OP is wanting something to drill up to 1/4 steel, bought a dud of a hammer drill, returned it, and is considering another hammer drill. The inability to drill most brick is secondary to the fact that the fact that they are even more useless for heavy metal but is another reason to not buy another.A hammer drill works great on brick and block. Been there done that so many times I can't count.
I will say that my 12v sds is faster though, so I usually use that now instead.
I disagree with you and stand by my statement as well that they do great in brick. Not soft brick, but all brick. Maybe you had lousy hammer drills, I don't know. All I know is mine works great, just a tad slower than my m12 sds.If you go back to post 40, I already said hammer drills are ok on concrete block. I stand by my statement that they are useless on most brick. Maybe you've only encountered the soft brick, of which I've been able to drill into with a masonry bit and a regular (non hammer) drill. The merit's of a hammer drill in brick and block don't matter in this thread anyway. The OP is wanting something to drill up to 1/4 steel, bought a dud of a hammer drill, returned it, and is considering another hammer drill. The inability to drill most brick is secondary to the fact that the fact that they are even more useless for heavy metal but is another reason to not buy another.
It really doesn't matter what either one of us think about a hammerdrills ability to drill brick. The OP is concerned about drilling a 5/8 hole through 1/4" steel. A hammerdrill is going to be useless for that, the fact that they are almost useless in brick is secondary.I disagree with you and stand by my statement as well that they do great in brick. Not soft brick, but all brick. Maybe you had lousy hammer drills, I don't know. All I know is mine works great, just a tad slower than my m12 sds.
TrueIt really doesn't matter what either one of us think about a hammerdrills ability to drill brick. The OP is concerned about drilling a 5/8 hole through 1/4" steel. A hammerdrill is going to be useless for that, the fact that they are almost useless in brick is secondary.
@sparky 1971
I always appreciate your advice on GJ, but something is amiss here.
As I posted earlier in this thread, i’ve used and owned several hammerdrills over the years and one that I dont know the model number right off, but similar to the Milwaukee 5380. The hammer mode is selectable. And it has two speed ranges. So, in non-hammer mode and low-speed, its really no different than a regular drill. They are even manufacturer rated the same capacity for steel.
The high speed range gives an advantage for drilling smaller holes in metal.
As much time as i’ve spent behind a spade drill, there’s no way i’d recommend one for the OP’s needs.
Lots of knowledge on here and again, thanks for all you share.
Hammer drills ****. More than a couple holes and you might as well use a roto hammer, even little holesI disagree with you and stand by my statement as well that they do great in brick. Not soft brick, but all brick. Maybe you had lousy hammer drills, I don't know. All I know is mine works great, just a tad slower than my m12 sds.
Workforce also makes a 5/8" spade handle drill mixer with a variable speed from 0-750. Would that serve my purposes better for drilling through 1/4 mild steel? It also sells for about $90. The Bosch I purchased was variable speed but the variable speed quit on me before I got the four holes drilled.I haven't had a corded hammer drill for over 20 years. I do have a M18 that has the hammer function, but it's never been used to drill concrete or brick. Low gear on that is actually low gear
The drill that the OP bought is 0-3000 rpm with no low gear.
Bosch® 7-Amp Corded 1/2" Hammer Drill
The Bosch® 1/2-inch keyed chuck corded variable speed hammer drill has a dual-mode selector; it easily converts from rotation-only to hammer drill mode. It has an ergonomic handle with multiple gripping positions for increased comfort and control. It includes a hard case for easy and convenient...www.menards.com
That's way too fast for anything of a decent size in steel. That drill gave up the ghost and he's considering the two speed, but in low, that drill is 0-1300 and I think that's still too fast for 1/4 thick steel.
Masterforce® 10-Amp Corded 1/2" Hammer Drill
This Masterforce® 1/2-inch corded hammer drill includes two speeds that are controlled by an easy-to-use box switch to accommodate a variety of concrete, wood, and metal projects. In addition, the soft-grip handle and lock-on button offer comfort during extended operation, so you can work longer...www.menards.com
The last corded hammer drill I used was a MIlwaukee 1/2". It's the same drill that I tossed in a trash can and bought my first SDS when I kept burning up masonry bits trying to get a 5/16 hole in brick. It wouldn't run a 1-3/8 step bit into a panel tub. My Panasonic 15.6 drill would do that effortlessly. It was the same thing, but on a smaller scale with the 3/8 MIlwaukee hammer that my previous employer had, and that was a repeat of the same experience with a 5/8 Makita. There have been other hammer drills that I have used, but most of them were just clones of the Milwaukees. Every one of them was the same...not good at anything but better than nothing.
It would probably be about the same as the Masterforce. Once you get away from the big brand names they are all about the same. Just stay away from hammer drills, and for what you are doing, keep the max rpm low.Workforce also makes a 5/8" spade handle drill mixer with a variable speed from 0-750. Would that serve my purposes better for drilling through 1/4 mild steel? It also sells for about $90. The Bosch I purchased was variable speed but the variable speed quit on me before I got the four holes drilled.
Oops, I meant to write "MasterForce." No need for hammer drill for drilling metal, but I suppose I might use the hammer function for some unforeseen use. Yes, I do need to keep the speed slow on drilling metal or else overheat and ruin an expensive bit. That is why I got the variable speed on the Bosch drill, but it played out quickly. Thanks for all the good information.It would probably be about the same as the Masterforce. Once you get away from the big brand names they are all about the same. Just stay away from hammer drills, and for what you are doing, keep the max rpm low.
I wouldn't have an issue using the Masterforce drill a few times a year. A hammer drill could potentially be useful if it's all you have for drilling concrete, but you would find it worthless if you were to try to drill that 5/8" hole through 1/4" thick steel. Get the regular drill, then, if the need arises there can be another Garage Journal argument about hammer drills VS rotary hammers.Oops, I meant to write "MasterForce." No need for hammer drill for drilling metal, but I suppose I might use the hammer function for some unforeseen use. Yes, I do need to keep the speed slow on drilling metal or else overheat and ruin an expensive bit. That is why I got the variable speed on the Bosch drill, but it played out quickly. Thanks for all the good information.
Thanks for the good information. I recall a several years ago I had to break up some concrete. I went to a local rental place and the appropriate tool to do so. It was a lot heavier than even a 1/2 drill. I suppose hammer drills have their purpose but not for my purpose of drilling a hole through metal. Thanks again.I wouldn't have an issue using the Masterforce drill a few times a year. A hammer drill could potentially be useful if it's all you have for drilling concrete, but you would find it worthless if you were to try to drill that 5/8" hole through 1/4" thick steel. Get the regular drill, then, if the need arises there can be another Garage Journal argument about hammer drills VS rotary hammers.
EDIT: when I say Masterforce, I mean the D handle, not the hammer drill.
