Recommended laser parking system.
IH82BL8
Bowie, Md
I just bought a new pickup and it will barely fit lengthwise in my garage. I need to install a laser parking system to avoid bumping the front wall. Can someone recommend a system based on personal experience?
Thanks.
DRC12345
Toronto, Ontario
Not my garage, but easy and free!
fnieto
Tucson,Arizona
I don't have this issue, but relying on electronics could fail resulting in contact. If you are that tight than a mechanical solution might prove a better solution. The tennis ball is really a simple fix. A painted line would be open for interpretation by another driver resulting in said contact.
LS6 Tommy
Northern NJ
Came out of the last Exxon I managed before it was torn down. I have it set in my garage so when the back tires go over the hose and it dings, I stop.
Tommy
Milehighxr
Lpngmont CO
I have a bright green glove hanging from the ceiling, like a tennis ball. I have it set so I can get the car in, and the hatch open with the overhead door closed. It works perfectly, I wouldn't trust anything that relies on electronics. The concern for me is making sure the car is in, but also close enough to the door, that I can still use my shop space in front of the cars effectively.
RVDan
North America
I have a piece of 2x4 glued to the floor with silicone. I tried the tennis ball but it was always ******* me off when I walked in without the car parked there, and tying it out of the way meant I'd forget to put it back down.
I couldn't get the geometry right to have it go up and down with the garage door.
