I am restoring an old Record Vise. I will add some photos later but need some advice here:
the Slide that surrounds the lead screw is the regular square style but when viewing the vise from the back you cannot see the lead screw; it is enclosed by the slide on the backside. so the slide it self is fully enclosed except for the bottom
I cannot disassemble the vise because as you unwind the lead screw to widen the jaws, all the pieces of metal collide and i do not see any that can be removed. if you flip the vise over you see a small pin hammered into the shaft of the lead screw and it is their to hold a spring in place around the lead screw. if i remove that it does not seem like it would allow the vise to come apart.....
any clues?
Thanks!!
any clues?
Thanks!!
