Paperman
Bought a large building that was a warehouse. A section of that was your basic red steel structure that was insulated. The walls have been hit by fork trucks pushing them out in a few places a buckling the siding. The other side of the building was a heat treat/powder coating area so there is a number of large holes in the walls from ventilation units and exhaust. I plan to remove the skin from the pushed out section, shorten it to the correct length and install it on the wall with all the holes.
Now onto the question, the insulation on both walls is torn up from forklift operators getting a bit to close and tearing it. With the skin off where does one find the insulation used on steel buildings? Is it as straight forward as one assumes, hang it from the upper girt and install the siding over it? Thanks all.
