ShadowRuleZ
Maybe I'm over complicating it, but I've spent a good chunk of the evening trying to understand all of the various inserts that are available. I have a hole that was originally 1/4-20 and someone opened it up to the next size, 5/16-18 (this is to hold in a set of vise jaws). I would like to get back to the original size. Please give your feedback, other ideas, or please point out if I'm wrong.
I've never used inserts before, but they sounded like the right idea. First thing I did was look at helicoils. From what I've found, the 1/4 insert uses a 17/64 (.2656) hole that needs to be tapped with a specific tap. However, again from what I've found, a 5/16 hole would have already been drilled with a J bit (.2770) and when tapped the outer threads would be 5/16 (.3125). So to me, that sounds like I can't use a helicoil since it's already too large. Time-serts seem to have the same requirements.
The only other thing I could find were EZ Loks. These would let me use a 23/64 (0.3594) and 7/16-14 tap for the regular or a 21/64 (0.3281) and 3/8-16 tap for the thin wall. Those are both large enough to eliminate the existing threads completely, but I'm worried about how much metal is left if I open the holes that large.
Are there any other products I'm missing?
