Reed 403-1/2 stand
royce
fairbanks ak
I've had this very clean vise bolted to a taco cart for a number of years and it always seems to be in the way.
So a new stand is in order.
Starting with a 19-1/2 dia x 1" bottom plate, 11"dia x 3/8" top plate and 40' of 5/8" round bar.
It is laid out for 12ea 5/8" spokes, acting as the column
After laying it out, figuring all the spoke lengths and angles, it feels like it might not be rigid enough.
Think I'll try alternating directions on the spokes and see what that looks and feels like.
Royce
R
royce
fairbanks ak
Re-sketched it with crossed spokes.
Not sure I can visualize what all the effect atheistically it may have, but it should be stiffer anyhow.
Cut some legs from some 2"boiler tube, which gets the footprint up to 23-1/2" which is good for stability.
Royce
isb cornbinder
I make these simple stands. I have them under grinders and polishers. These stands work well. If I were going to use one of these stands under a vice, I would use heavier tube. A heavier plate under the vice should give additional stability. This design allow me to put a foot on the front cross-bar,
R
royce
fairbanks ak
Got the spokes tacked together and plug welded to the plates.
Also added a sprocket for counterweight and a couple of spacers for garnish.
It is surprisingly rigid, I would not think twice about putting up to a 4-1/2" vise on it.
Architecturally, it misses the mark to my eye, but that's alright.
Think I'll remove the spacer rings on the sprocket.
In the end it is fine for this 3-1/2" reed.
Royce
pamike
Central PA
Royce,
What was your occupation? Steel worker? Pipeline welder? You have a very unique skill set of both craftsman and eye for artistic aesthetic appeal. Your work always impresses...
R
royce
fairbanks ak
Royce,
Thanks pamike,
Started out when I was 15 in a old blacksmith shop that had evolved into a fabrication and machine shop then moved to uranium and gold mining, then pipeline welding, then mechanical welding and fabrication.
Royce
RMERR
Northern CA
Wow, this Mike Cooper guy, never heard of him before and I'm from Lodi. Talk about head shaking, jaw dropping next level stuff. I'm still in awe. Like the ultimate marriage of technology and art. I may have to buy his book. Thanks for the link.
