Refillable sprayers for garage use
Cryptic1911
Willimantic, CT
I picked up three of the sure shot (made in usa!) 1000 refillable sprayers for brake cleaner, pb blaster and wd-40. These things are awesome!.. no idea why I waited so long to get some :dunno: but I sure got tired of half full cans of brake cleaner running out of propellant :( Now I can just buy it in gallon jugs and refill these
Probably one of my favorite purchases in quite a while :rocker:
https://www.sureshotsprayer.com/SteelSprayers.html
anyone else use these?
loganb
Omaha, NE
Great...another product discovered here that will take my money eventually!
What are your thoughts on the size so far? I think I like the model M size better as I just don't spray anything that much to need the model A capacity. The 16 oz Model B is honestly the size that appeals the most but their note about valve maintenance makes me curious on what that maintenance cycle is on normal home garage/workshop usage.
Sent from my SM-N986U1 using The Garage Journal mobile app
supratreo
elk grove, CA
nice. i miss using these at the dealership. Zep45 ID red was the best cleaner i've used to date but the great state of CA doesnt want it anymore. where can i get brake clean in a bucket?
C
Cryptic1911
Willimantic, CT
The capacity is great, but realistically you aren't filling the whole thing to the top. You fill it like 1/2-2/3 and the top gets the air. I don't think the overall dimensions will be much larger than the aluminum ones once you figure in the size of the handle on the M model.
The nice thing with the aluminum ones is they are aluminum inside as well, so you can have water based stuff in them and they come only with adjustable nozzles. The steel A models are bare steel inside, so although oily stuff and chemicals is fine, water is a no no.. but you'll see people in the reviews complaining even though it says in the directions not to lol
The default spray on the steel 1000a models is kind of a cone mist. You can saturate a good area fast. You can pop the nozzle off and pull out a spiral thing and it'll shoot a stream, but I haven't really had the need yet. They do however sell different nozzles separately, like a long needle one, a couple flexible models and I think a couple others, so there is some ability to change depending on what you want to use it for
I bought it from amazon. Napa apparently carries it, but my local one couldn't find any that their computer said were in stock :dunno:
Not sure about CA, but in the slightly free-er states Amazon has Brakecleen in 1 gal containers
https://www.amazon.com/dp/B000CIPUU0/
Yup thats the exact one I bought. Picked up a gallon of wd-40 from harbor freight and used a coupon and the pb blaster I got from advanced auto.
nadogail
Coronado, CA
In another place, at another time, We did not use a Special Cleaner for brakes, carbon tetrachcloride which was packaged as Fire Extinguisher Fluid worked fine.
nzjkb5
Knoxville, Tennessee
The Sure Shot 1000 is awesome, I keep mine filled with lacquer thinner for general clean-up jobs. Would love to find a deal on them to get a couple more in different colors for other solvents, though. $45+ a pop is a little tough to swallow to have multiples. The knock-offs at $28 each have spotty quality reviews.
HenryAZ
MEMBER EMERITUS
South Congress AZ
I use one Sureshot, filled with denatured alcohol for general cleaning and degreasing. For heavier viscosity fluids, I prefer the Dutton-Lainson pump oilers. Some models have adjustable spray tips for lighter weight fluids.
kaymccampbell
Upstate New York
Which is why older mechanics, typewriter repairmen, and printers had essential tremors and cirrhosis. Nowadays they get it from drinking too much.
Metallitubby
ATL OTP North
Another user of SureShot sprayers for 20sh years or so. I haven't seen the long-nozzle ones in years, and wasn't sure it was still being made.
C
Cryptic1911
Willimantic, CT
It doesn't look like you can buy them with that nozzle on by default, but I've seen the nozzles for sale separately. I think I saw them on zoro tools
ynned
N.E. Ohio
I just use old spritzer bottles after they're empty. We always seem to have several containing some kind of cleaner or something. I look for the ones that have a two position nozzle for stream or spray.
LeonardY
Southern California
You can still get in CA. Just not consumer stores. IE. HD, Lowes, etc.
Grainger carries it. It's the same for the old formula for Krylon. It's now labeled Industrial Krylon.
