(relatively) inexpensive stud remover tool?
firebox40dash5
Does that mayhew ruin the threads at all when you use it?
Ohhhhhh yes. :lol:
But, it'll get about anything you can get it onto, off. I successfully got 15 of 16 exhaust manifold studs off a rusty as hell (plow/salt truck) PSD 7.3 with one. Only reason I couldn't get the last one was that it has 'turned' it down so much the first couple tries there wasn't enough diameter left for it to get a good grab.
bw77
Upstate NY
So which is it, USA or Taiwan?
http://www.amazon.com/dp/B000XSCDEA/?tag=atomicindus08-20
Mayhew Stud Extractor is designed to fit a 3/8 inch impact wrench and fits all the studs from quarter inch to half inch. It is made in U.S.A and is easy to use.
Product Description
The Mayhew 29895 Stud Extractor is used to remove seized or broken studs and bolts. Designed to fit into small areas, where studs may be hard to reach. Made out of high-grade, heat-treated alloy steel. Chrome finish for additional rust protection and aesthetic appeal. Use with a 3/8-Inch impact wrench, on low. Made in Taiwan to Mayhew's specifications. Comes with a 2-year limited warranty.
dmeadow
Houston, Texas
Hawk321
Germany
I doubt that Klann makes them....guess Klann buys them in oversea and sells that goodie for 400% more.
For me, those 1/4" Turbosockets worked perfect. Maybe you get a set from 6 - 10 mm inlcuding inch sizes.
refried
San Juan Islands, WA.
I've had good luck with these
