I added a doorbell to my circa 1950's house that never had one. pulled the inside casing off , drilled a hole in the outer-casing inwards, ran the wire ( between the door jamb & stud) drilled a hole at the bottom into the basement .
Not sure if the video ones need shielded cable or are they are wireless and just use a power feed?
The door bell will obviously have a bigger field of view but I took pictures from both sides. As you can see the wall next to the current location blocks quite a bit. I know they have small wedges available to angle it a bit to one side so that's what the last picture is simulating. I was afraid I would need to remove trim to relocate, these things are never easy lol. Now I'm debating on just getting another nest cam instead of the doorbell since that will be a more hassle free install. If you look closely the previous owners must have had the ring doorbell with the battery on the left side
Sent from my Pixel 3a XL using Tapatalk
Only time you need shielded low voltage power wire is for burglar alarms and fire alarms.
These aren't normally shielded, at least for residential. They have a jacket rather than two loose strands (loose strands is typical for doorbells) but not shielded. Shielded means a conductive tube of some sort around the wires for electromagnetic field interference reduction. A non conducting jacket is not a shield.
Huh? Your reply makes no sense and I know what shielded wire is.
I was responding to someone else who asked if shielded wire was needed for a ring doorbell.
These were pictures taken with my phone, the doorbell has a much wider field of viewReally doesn't look like you gain much view on the left of the view from the other side. Just a sliver past the post. Your pictures seem to have very limited field of view too. I would just go with where it is.
Pulling the trim is pretty easy compared to other things that might have to be done.
You said:
Many burglar and fire alarms also don't require shielded cable - that's why I thought you might be referring to a cable jacket. I was describing what I usually see for security and fire alarm cable.
So I have plenty of attic space to walk up n drop a wire, just wondering if it's worth it to try and fish one of those small wires thought the insulation and out the stucco. I'm also considering stapling one around the trim.
If you can carefully remove the interior casing, ther should be room to hide the wires between the back of the jamb and the rough opening. I would do as suggested and go up and over.
