Remote switch hardwired to breaker?
thesillym
I have a commercial building that has a couple light circuits with no switches, just breakers. I want to add a wireless switch to each circuit that is hardwired in at the breaker panel. Simple and cheap solution is best and don't want to use a hub like Smartthings or wifi unless I have to. Distance of about 40 feet. Need 20 amp rating. Any suggestions?
Shiftless
East Bay SFO
Just Google “remote control relay switch” and you’ll get lots of choices. The ones I looked at had terminals for AC in and AC out. Where could you mount something like this where the bare terminals were protected except in a normal box that is used for switches and receptacles? If the relay was mounted in a metal box, would the signal from the remote get through the metal box? :dunno:
jlv03
SE IA
How much space on or around your panel? Funcitonal Devices has some Relay-in-a-Box style devices you could mount on the side of your panel.
T
thesillym
I do have plenty of space around the panel and the Functional Devices look like they would work great. I was hoping for something less expensive though, maybe $30-$40 per circuit.
